the record spot: ...
Equally, they seem to need a sub, which is the rage these days, but if AVI could design the Neutron speaker which produced respectable bass for it's size, why couldn't this box perform as well without a sub too, given it's bigger, and that's allowing for the internal amp and DAC? Perhaps I'm missing something...
The Neutron, even with amp-pack, is still a passive speaker and therefore probably has certain 'attributes' that make bass seem larger than it is, common with many passive speaker/amplifier systems. If I understand it correctly, it is the lack of control of the amp over the bass driver that gives that bloom/enriched upper bass or whatever you want to call it, something inherent even in the most proficient passive designs. With the ADM's, the amplifiers have been specifically designed to assert sufficient control over the drive units, without the 'sound-degrading' xover in between power amps and drive units.
I can tell you first hand that this establishes itself as slightly 'bass lite' if you come straight from a (not so well executed) passive system but it also very fast, very transparent and 'life' like, at least with voices and instruments which are easier to break down into what is realistic or not. The system can easily play back a wide variety of instruments in a live like manner as far as I could discern and even makes a fairly good attempt at double bass. It is ultimately limited by it's size and (in)capacity to move air. The sub fills in where the system rolls off. Many use them without, I'd certainly use one.
There have been a number of remarks along the lines of ... ' they may be transparent etc but are they emotional? In my opinion, on the 3 or 4 occasions when I heard them, they cover that side too. Keb Mo sounded warm, life like and thoroughly dynamic. It's been a while but thats my overlasting impression.
As regards to Ashley James, he has a 'certain' way with regards to representing his products but that does'nt take away that he is a thoroughly decent and knowledgable person. I'd urge anyone considering spending around the AVI ADM9.1's amount of money on a system to try and listen to them and forget about any comments from AVI or forum members. You won't have Ashley James living with you but you might find the only system you need for a long time. - I am in quandry in that I've listened to Naim's XS/CD5x and have to make my mind up on which system to get. Proof, if anything, that I am in no particular 'camp' regarding the technology vs. sound. Both are excellent and both are the only two systems I consider buying. I've heard a few ...
