AVI ADM 9RS Mini Review
techboy said:
ADM AVI 9RS Mini Review[/b]
SETUP[/b]
ADM AVI 9RS on custom desktop stands
Surround and sub duty by Swan M50W 2.1
DAC / Preamp Setup 1 : Asus STX, Project Ember by Garage1217.com
DAC Setup 2 : AVI Built in DAC
OTHER SPEAKER SETUPS OWNED:[/b]
Aktimate Micro Asus STX Swan M50W Project Ember
Aktimate Mini+ Asus STX Swan M50W
Swan H5 Asus STX Swan M50W
OTHER HEADPHONE SETUPS OWNED:[/b]
Sennheiser HD 650 Project Ember Asus STX
Sennheiser HD 598 iPad 3 iPhone 4s
PLEASE NOTE[/b]
HD 650 has been properly amped by Project Ember which is an amp comparable to Schiit Lyr, Graham Slee, Lehmann BCL etc. I have also tried it with Beta22, so I know how HD 650 sounds.
I still believe that HD 650 are awesome headphones, just that AVI is a step up from them, while still a step below HD 800.
IMPRESSIONS[/b]
Initially, I was disappointed not having heard any speakers for the last few days except my Sennheiser HD 650 setup. But now that the speakers are slightly burned in, I am used to it and tried my HD 650 setup again, I can easily say that ADM AVI 9RS trumps my HD 650 setup. I don’t even want to compare it to Aktimates because they seem unlistenable after hearing to AVIs for a few days.
Don’t get me wrong, from a value for money perspective, Aktimates are still the best there is, but if you can afford ADM AVI then there isn’t much of a contest really.
After listening for a while on my AVIs I went back to my HD 598s and they sounded muddy and distorted in comparison. And they used to seem like heaven compared to my Aktimates. They were a huge step up from my Aktimates and now they are nearly unlistenable.
HD 650 is still much better than HD 598 now, which I didn’t appreciate as much earlier. HD 650 is comparable to AVIs but AVIs are better in many respects and often by a significant margin, so you can perhaps call them LCD2 territory. As AVIs aren’t as resolving of details as HD 800. I have listened to both HD 800 and LCDs properly amped.
MIDS[/b]
HD 650 and AVI both are mid centric setups. AVI has clearer mids by some margin I guess. However, HD 650 has thicker vocals. I would give this one to AVI.
LOWS[/b]
HD 650 has more bass, but AVI has tighter and sharper bass. Both are very good but again AVI is more audiophile like.
HIGHS[/b]
Both are very good, but AVI seems at least as good if not better.
TRANSIENTS[/b]
AVI is clearer and sharper here, HD 650 is more natural but sounds muddy in comparison.
IMAGING[/b]
AVI is better than anything I have heard before for stereo, including HD 650.
TRANSPARENCY[/b]
AVI is a step up. As transparent as it gets. Though I don’t find HD 650 veiled either with my amp, but AVI is just better.
SOUND STAGE[/b]
AVI is wider, deeper and taller.
[/b]
CENTER STAGING[/b]
Not even a contest, AVI hands down.
[/b]
LOW VOLUME LISTENING[/b]
AVI wins.
AVI is cleaner, clearer, more transparent though not sure whether it is more resolving or not, perhaps about equal, the two of them, not sure though.
HD 650 is excellent but AVI is just better but both are very listenable
HD 650 is better than cinema grade sound I would say, but AVI takes it a bit further with being more refined.
I have only tried with my Preamp so far.
With the inbuilt DAC (and not my preamp): It sounds slightly cleaner, but slightly less lively. Though the two are very close. However, without inbuilt DAC/without preamp, it doesn’t sound as good as I described it above, then it sounds a step below the above description.
And AVIs are not analytical at all, they are musical, perhaps not as much as HD 650, not sure about it, but definitely very musical and resolving, very transparent as well.
Thank You
Aakshey
PS:
Lows are not overpowering but are there nevertheless. It is mid centric. Lows are there but not emphasized.
Lows in AVI are tighter but well controlled and textured, not as powerful though.
Please Note
They don't sound like Aktimates at all. Aktimates have a wow effect which these dont on initial listen. Aktimates sound crisp and bright which gives that wow effect. These are opposites, a smooth resolving and transparent which isn't bright at all nor crisp but very love able once you listen for a few hrs. After that there is no going back to it. It is a super clean and transparent sound which makes Aktimates sound muddy in comparison, infact unlistenable once you get used to these.
I have updated the review. Lows on avi are tighter, check updated reply I gave you
It can. Because headphones usually have higher resolution and clarity. But not in this comparison.
I think I got the part about dynamics wrong, HD 650 is very dynamic as well, perhaps more so, not sure about that though.
In short, HD 650 and AVI ADM9RS are very close to each other in overall performance with AVI may be being a bit better overall, in several aspects that too. But both are very comparable.
HD 650 is definitely lusher, sweeter and more musical though. Though there are lots of place where AVIs are very close or better than them.
I prefer to listen to AVI over HD 650 unlike with Aktimates where I never listened to them and spent time only with HD 650
AVI ADM9RS is for 1.5 L. 9RSS is for more than 1.6+ L but not released in India yet. None of the current models come with a sub. The AVI sub is about 1L extra.
I got a discount which I won't disclose
Anybody in Delhi can audition at my place.
After more usage, their strengths and weaknesses are more evident.
If you want HD 650 (about equal, better in some ways, worse in others) in speaker form albeit with slightly lesser bass and slightly more neutral, then AVI ADM 9RS should be the obvious choice.
HD 650 are more musical, sweeter and lusher. AVI are more neutral (which I like actually), slightly cleaner, slightly more transparent. Imaging of both is very good. Centerstaging of AVI is definitely better. AVI is also less grainy. AVI is very refined and resolving for a speaker setup
Both are excellent and kings at their respective tasks
Having both together is much more than a dream come true
Thank You so much!
Aakshey
A fair subjective review and comparison.
It's a pity that you weren't able to compare them to live music rather than just headphones, as a comparision to live music is much more telling most especially as regards how the speakers perform objectively, or perhaps if you'd been able to arrange some blind, matched level testing against other similar speakers.
But it is good that you like them, and your testing has established a subjective preference for you.
Don't pay heed to the politics re comments - AVI unfortunately has a bad rep here due spamming and proselytising, and they also are quite capable of handing out all manner of insults themselves when it suits them, whilst trying hard to project an impression of being the victim in most circumstances - a behavioural trait which also doesn't win them friends, along with denigrating other manufacturers products that don't fit with their philosophical take on HiFi design, which as you could well understand, puts a lot of people off side.
Putting the politicking and rudeness aside, I'm sure they're a good product that will give you a lot of pleasure and I wish you luck with them.
Congrats and enjoy.
JMac
John Duncan said:
Alec said:
Of course, not so long ago, Mr Duncan was wondering - it seems most disingenuoulsy - what they say about him over there.
So I signed up to find out. I couldn't help myself.
There are those who would happily have told you.
Were you there when I was "banned"?
Phileas said:
John Duncan said:
I am, which was why I asked the question.
In a sarky manner, to a new poster you assumed was a shill.
No, to someone who appeared to construct his post from three *separate* posts on another forum. A forum, moreover, which happens to be run by the manufacturer of the product in question, a manufacturer who has a reputation - whether deserved or not - for using spamming techniques on other forums. Galatians 6:7 - for our bible-quoting friend's benefit - is helpful in this regard.
I didn't realise you were banned from AVI's forums Alec.
Actually it would be interesting to know just how many of us here have been banned from AVI's forums for daring to question their approach to things HiFi.
I have never been privy to what was writen about me behind my back after I was banned, and with no right of reply, but I gather it was quite unpleasant, judging from the emails I received gloating about the matter.
Nothing quite like being banned from a cult... one is seemingly deemed to be a sinner worthy only of crucifixion in their eyes....
JMac
Oh I knew already, but sometimes the lawyers need screenshots. You know how it is.
Ha, I am not narrowing down the timeframe, Ashley will have to find me for himself. He does appear to have adopted the habit of checking every user's IP address as soon as they join, and doing things like blurting out their location (in contravention of the Data Protection Act, I might add) but sometimes he does get stuff wrong...
Oh I knew already, but sometimes the lawyers need screenshots. You know how it is. Ha, I am not narrowing down the timeframe, Ashley will have to find me for himself. He does appear to have adopted the habit of checking every user's IP address as soon as they join, and doing things like blurting out their location (in contravention of the Data Protection Act, I might add) but sometimes he does get stuff wrong...
As do you an dAndrew, according to one source who shall remain anonymous for now at least. It isn't good for anyone to try and fit anyone up.
JMac
I put the word in quotes because i asked to be banned, and threatened certain action if a ban - which I had requested before - was not forthcoming.
He had no choice, and I've no interest at all in what has gone on there since.
Alec said:
As do you and Andrew, according to one source who shall remain anonymous for now at least.
I can assure you that Andrew most certainly does not.
I, however, do use the IP address tools available to me when I suspect a poster of breaching the house rules regarding multiple registrations. I have found them quite helpful in the past, particularly on the odd occasion when the IP address has been found to originate from the Republic of Ireland.
I do not, however, go on to share any information that the site's administration tools provide me on a public forum unless specifically asked to by members, having signed up to the Data Protection Act and having been made aware of the consequences of divulging information to which I am privy (a fine of up to £500k, IIRC).
altruistic.lemon said:
They disappeared me! All posts deleted, no trace left.
That must really screw with their SEO. I seem to recall when they banned me I was accessing from my (mandated) corporate VPN, thus potentially simultaneously banning about 140,000 well-paid, tech-savvy IT professionals worldwide...
Guys ,
Y'all got banned ?
Wish I'd got banned from here 3 months ago , came on to ask about a speaker setup ended up buying a new HT set up , a really cute little mini amp and now I'm 2/3rd's convinced I need a new amp ( and I don't know why ) , re-copying all my cd's in lossless format while looking at pictures of peoples podium hi-fi racks :help: :?
James
JamesMellor said:
Guys ,
Y'all got banned ?
James
Now don't be like that.....we've only just got started!.....so much good stuff; so little time. :shifty:
My Neice and Nephew thank you Cno , they are really cool with thier college funds being renamed rotel 15xx or NAD xx or Tecnics 9xx or Arcam pxx fund , they should learn from thier loss
James
James
I like to think I pull my weight. :twisted:
yeah so a good / decent system to let themmake choices later ,
I am sure my system is far from perfect , but in evolves from my fathers music and his hand me down components
