ADM AVI 9RS Mini Review[/b]
SETUP[/b]
ADM AVI 9RS on custom desktop stands
Surround and sub duty by Swan M50W 2.1
DAC / Preamp Setup 1 : Asus STX, Project Ember by Garage1217.com
DAC Setup 2 : AVI Built in DAC
OTHER SPEAKER SETUPS OWNED:[/b]
Aktimate Micro Asus STX Swan M50W Project Ember
Aktimate Mini+ Asus STX Swan M50W
Swan H5 Asus STX Swan M50W
OTHER HEADPHONE SETUPS OWNED:[/b]
Sennheiser HD 650 Project Ember Asus STX
Sennheiser HD 598 iPad 3 iPhone 4s
PLEASE NOTE[/b]
HD 650 has been properly amped by Project Ember which is an amp comparable to Schiit Lyr, Graham Slee, Lehmann BCL etc. I have also tried it with Beta22, so I know how HD 650 sounds.
I still believe that HD 650 are awesome headphones, just that AVI is a step up from them, while still a step below HD 800.
IMPRESSIONS[/b]
Initially, I was disappointed not having heard any speakers for the last few days except my Sennheiser HD 650 setup. But now that the speakers are slightly burned in, I am used to it and tried my HD 650 setup again, I can easily say that ADM AVI 9RS trumps my HD 650 setup. I don’t even want to compare it to Aktimates because they seem unlistenable after hearing to AVIs for a few days.
Don’t get me wrong, from a value for money perspective, Aktimates are still the best there is, but if you can afford ADM AVI then there isn’t much of a contest really.
After listening for a while on my AVIs I went back to my HD 598s and they sounded muddy and distorted in comparison. And they used to seem like heaven compared to my Aktimates. They were a huge step up from my Aktimates and now they are nearly unlistenable.
HD 650 is still much better than HD 598 now, which I didn’t appreciate as much earlier. HD 650 is comparable to AVIs but AVIs are better in many respects and often by a significant margin, so you can perhaps call them LCD2 territory. As AVIs aren’t as resolving of details as HD 800. I have listened to both HD 800 and LCDs properly amped.
MIDS[/b]
HD 650 and AVI both are mid centric setups. AVI has clearer mids by some margin I guess. However, HD 650 has thicker vocals. I would give this one to AVI.
LOWS[/b]
HD 650 has more bass, but AVI has tighter and sharper bass. Both are very good but again AVI is more audiophile like.
HIGHS[/b]
Both are very good, but AVI seems at least as good if not better.
TRANSIENTS[/b]
AVI is clearer and sharper here, HD 650 is more natural but sounds muddy in comparison.
IMAGING[/b]
AVI is better than anything I have heard before for stereo, including HD 650.
TRANSPARENCY[/b]
AVI is a step up. As transparent as it gets. Though I don’t find HD 650 veiled either with my amp, but AVI is just better.
SOUND STAGE[/b]
AVI is wider, deeper and taller.
[/b]
CENTER STAGING[/b]
Not even a contest, AVI hands down.
[/b]
LOW VOLUME LISTENING[/b]
AVI wins.
AVI is cleaner, clearer, more transparent though not sure whether it is more resolving or not, perhaps about equal, the two of them, not sure though.
HD 650 is excellent but AVI is just better but both are very listenable
HD 650 is better than cinema grade sound I would say, but AVI takes it a bit further with being more refined.
I have only tried with my Preamp so far.
With the inbuilt DAC (and not my preamp): It sounds slightly cleaner, but slightly less lively. Though the two are very close. However, without inbuilt DAC/without preamp, it doesn’t sound as good as I described it above, then it sounds a step below the above description.
And AVIs are not analytical at all, they are musical, perhaps not as much as HD 650, not sure about it, but definitely very musical and resolving, very transparent as well.
Thank You
Aakshey
PS:
Lows are not overpowering but are there nevertheless. It is mid centric. Lows are there but not emphasized.
Lows in AVI are tighter but well controlled and textured, not as powerful though.
Please Note
They don't sound like Aktimates at all. Aktimates have a wow effect which these dont on initial listen. Aktimates sound crisp and bright which gives that wow effect. These are opposites, a smooth resolving and transparent which isn't bright at all nor crisp but very love able once you listen for a few hrs. After that there is no going back to it. It is a super clean and transparent sound which makes Aktimates sound muddy in comparison, infact unlistenable once you get used to these.
I have updated the review. Lows on avi are tighter, check updated reply I gave you
It can. Because headphones usually have higher resolution and clarity. But not in this comparison.
I think I got the part about dynamics wrong, HD 650 is very dynamic as well, perhaps more so, not sure about that though.
In short, HD 650 and AVI ADM9RS are very close to each other in overall performance with AVI may be being a bit better overall, in several aspects that too. But both are very comparable.
HD 650 is definitely lusher, sweeter and more musical though. Though there are lots of place where AVIs are very close or better than them.
I prefer to listen to AVI over HD 650 unlike with Aktimates where I never listened to them and spent time only with HD 650
AVI ADM9RS is for 1.5 L. 9RSS is for more than 1.6+ L but not released in India yet. None of the current models come with a sub. The AVI sub is about 1L extra.
I got a discount which I won't disclose
Anybody in Delhi can audition at my place.
After more usage, their strengths and weaknesses are more evident.
If you want HD 650 (about equal, better in some ways, worse in others) in speaker form albeit with slightly lesser bass and slightly more neutral, then AVI ADM 9RS should be the obvious choice.
HD 650 are more musical, sweeter and lusher. AVI are more neutral (which I like actually), slightly cleaner, slightly more transparent. Imaging of both is very good. Centerstaging of AVI is definitely better. AVI is also less grainy. AVI is very refined and resolving for a speaker setup
Both are excellent and kings at their respective tasks
Having both together is much more than a dream come true
Thank You so much!
Aakshey
SETUP[/b]
PLEASE NOTE[/b]
IMPRESSIONS[/b]
MIDS[/b]
LOWS[/b]
HIGHS[/b]
TRANSIENTS[/b]
IMAGING[/b]
TRANSPARENCY[/b]
SOUND STAGE[/b]
[/b]
CENTER STAGING[/b]
[/b]
AVI wins.
Thank You
Aakshey
PS:
Please Note
Thank You so much!
Aakshey
