byakuya83 said:For less than 1,000 you could have the Dali Kubik Free. Their passive speakers are well reviewed. Not sure what the active versions carry in terms of power though - I believe there are more powerful alternatives.
Clare Newsome said:John Duncan said:I think the Cantons look pretty and useful - would work well with the Stream Magic as a preamp via XLR if digital inputs were all you needed. More attractive than the Quads anyway...
we're looking forward to seeing how the Cantons work as possible desktop companions to our A&K players (new AK240 has balanced output...)
AlmaataKZ said:
gasolin said:Have just got my Adam a5x (had the new krk rokit powered 5 g3) and they are good.
Can the hifi speakers with amplifer in one speaker and a cable from that speaker to a passiv one considered a real active speaker?
DocG said:Those Kyron speakers, mentioned in the comments, look the business (dipole, DEQX-controlled)!
I take it the price must be as outlandish as the looks...
EvPa said:DocG said:Those Kyron speakers, mentioned in the comments, look the business (dipole, DEQX-controlled)!
Australian price is roughly 110,000€/£90,000 per pair, if I remember correctly.
If you were to order the tweeters and midwoofers yourself, directly from Scan-Speak, you would already be looking at 1,200€/£1,000 per speaker; I don't know the unit cost of those 12'' woofers.
Broner said:gasolin said:Have just got my Adam a5x (had the new krk rokit powered 5 g3) and they are good.
Ah, so we both have the A5X's right now 🙂.
unsleepable said:Broner said:gasolin said:Have just got my Adam a5x (had the new krk rokit powered 5 g3) and they are good.
My Q Acoustics BT3 also have the amplifier in the right speaker, and a rather flimsy, thin and unimpressive cable to the left one that connects that to the left one.
I've thought about changing the cable for at least a better looking one. It is the only analogue cable that I can change since I connect the audio to the right speaker with an optical one. And I'm not a big believer in cables… But now I think, what if I change THE cable and now both speakers sound different?!?
gasolin said:Broner said:gasolin said:Have just got my Adam a5x (had the new krk rokit powered 5 g3) and they are good.
Yes. (mine are just new)
The a7x is much more expensive so i chose the a5x, which is perfect for my isoacoustisc 155 stand (desktop) and the only difference with the adam a7x is a few hz and a about 4db higher spl for about 320€,265€ extra.
https://www.facebook.com/AdamProAudio/photos/pb.465335556846675.-2207520000.1397214112./692786590768236/?type=3&theater
Clean,open, sound with lots of power
gasolin said:I personally would buy the A5X with stands instead of A7X without stands (which is cheaper), but on the other hand if i had a big room i would want the A7X
EvPa said:gasolin said:I personally would buy the A5X with stands instead of A7X without stands (which is cheaper), but on the other hand if i had a big room i would want the A7X
Nah, if you had a big room you would want a pair of S7A Mk2.
