John Duncan
AEJim said:Well we might be starting that from the other end - I'm just finishing up our new budget range (imaginatively titled "1-Series") which are looking and sounding very good indeed, even if I do say so myself! 😀
I've set things in motion for the standmounts to have an active version somewhere down the line, probably would retail at £500-£600, possibly followed by the floorstanders at just under £1000...
The active floorstanders in particular would be interesting as there simply aren't many around at any price, let alone at the budget/mid level. I still need to figure out the best connectivity options, do we keep it simple like the AE22's and let people choose their own pre-amp/dacs or try to put it all onboard with umbilical connector between the speakers? :? The simple line-level in is of course easier for us but I'm not sure it would be as readily accepted as a full-blown solution which you can connect directly to a source for the home market.
I think I'd probably be OK with single inputs if it kept the cost down - most people will just plug a Sonos or similar in the back, which will give them remote volume. My StreamMagic has a preamp mode which would do the same job (and also has balanced outputs, hint hint...).
You could stick a little cubby hole in the floorstanders to hold a Sonos, and give it an AC out to power it... :-o
