Which bookshelf speaker & Integrated amplifier
Hi, Dynaudio Emit 20 are very good speakers, not so demanding on amp as typical Dynaudio speakers. Those speakers will sound very good with lively amp like Rega Brio, Rega Elex mk4, Arcam A5, Arcam A15 and similar. I just do to recommend to pair them with "romantic or sirupy" sounding amp, small tube amp or similar. With last Rega amp, you can combine your system with some decent streamer like Bluesound or WiiM and let it run via digital input in Dac in those amps. Also Dac is if very good quality here. Or take some good turntable like Rega or Project with MM cartridge and you will have a very good sounding system for small room not annoying your neighbours. Best Regards.
Hi thank you for the recommendation.I just change the emit 20 in the description and i put the evoke 10 from what i see and read from reviews are better than emit 10.About the amplifiers, you are absolutely right especially Rega Elex mk4 is amazing amplifier.Rega for me is one of the top brands worldwide,excellent sound excellent build quality and prices.And the one of the rare brands that have lifetime limited warranty of specific products.
Thank you so much for your recommendations!!!The thing is that i prefer the sweet,warm,smooth sounding speakers and this also because in nearfield environment and for long sessions you need a speaker that has "gentle" sound if you allow me the expression.Because argon 1 has titanium tweeter maybe it doesn't have the warm sound that i prefer? The Rubikon 2 do you know if they are suitable for nearfield listening aprox 1,5 meters and for small room?Also are they warmer sounding than Argon 1? About the Neat because its a floorstanding its not for me because i want the speakers tweeter to be in my ears hight and this is aprox 1,25 meters.
Hi Harris.
I've no experience of the new Rubikon Range.
The Neats, although a floorstander takes up no more space than the Argons, once you factor in the speaker stands. They are just as shallow, ideal for small rooms. I certainly wouldn't dismiss them without hearing a pair.
Smooth or warm presentation will depend mainly on the amp that's powering them. There needs to be the right balance between informative and everyday listening. One thing I dislike is a forward sound - a bright sounds tends to be impressive for about the first hour, after that it starts to grate.
For a smooth presentation, can't go wrong with Q Acoustics. They are very good but if your amp veers on the same side (lush or creamy) it can sound dull after a while. This is why a demo is so important.
Reactions: Harris ARP
Hi Harris.
I am in the same page with you i do not like the forward bright sound its not for my ears and for long listening.For me its not even for 10 minutes!!!For the Neats its not the overall size its the hight because when i sit in my office chair (i will connect all the system with my pc) my ears hight is aprox 1,25 so floorstandings are not an option for me.You can't understand how hard is in Greece to find to audition the speaker you want.I will give you an examle. The other day me and a friend of mine we call the dealer of Dynaudio (hifi) in Athens asking him to audition the evoke 10 or 20.And he said that they we will never have this model for a demo and they only have emit models from their lower price models.So here audition speakers its like you win a joker you have to be very very lucky lol!!! Q Acoustics has always great reviews for their models especially the low cost ones.
Reactions: plastic penguin
No replacement. Their production cost was too high to maintain the price point. They were already close enough to the Argon 1. Shame, as it was a great little speaker that worked really well in small spaces.
Yes, I can envisage that. I like the Amphion range, works a treat with my amp. There's the crux: I've no idea what other amps sound like with the Argons
Not overly fussy really, they're much like any other speaker of its size, only without the 'dazzle'. I'd say more care needs to be taken with partnering once you reach the 3S, as from there on up they're sealed cabinets.
Be cautious. Small speakers usually demand a lot of current to really come alive.
A good speaker on paper and in certain circumstances can sound dreadful if not employed correctly.
Lifelike, punchy, controlled and musical, small room, normal listening * levels, I’d put my money on NAIT 50 and some NEAT Petite Classics.
It’ll be great.
Neat Petite have amazing reviews everywhere!!The thing is that many of them says that are very difficult in placement.Are they good for long listening without fatigue?
Why not recommend the ATC SCM11 @The_Lecht_Rocks ? They're a better fit to the budget and you've just bought a pair.
might be in the Petite boat myself soon........the ATC's work in a defined way. both the SCM7 and 11 will work in the OPs room size, and being sealed box most likely not affected by positioning. But the Petites will dig deeper and dependent upon acoustics, could sound better.
i thing N50 + Petites is a very safe musical bet
That's why I've excluded ATC,s from my list.They may be fantastic speakers, but they have limited bass and I don't want to buy a sub.
Have you heard them?
I wouldn't consider the SCM11 bass to be lacking, simply accurate.
That said when I auditioned them I decided on the EB Acoustics EB2 which were larger and cheaper.
If bass is lacking its because they are being used in the wrong setting with an underpowered amplifier.
That said Naim / Neat has always been a classic combo.
yep; the ATC are superb speakers and the Nait 50 has plenty of wallop to drive the SCM11s.
I'm swaying between the SCM7/11 and the Petites myself.
The ATC's notably cheaper....
