Bookshelf Vs Floorstanders, no context in my experience.
As I read that, I thought Mosecco 6s was a breed of cat - one third filled with Atabites 😁
Seriously, some floorstanders are surely (at least) as vulnerable to sideways pushes as stands.
Unfortunately they are. My wife managed to clobber one of mine and down it went.
Lovely lacquer now missing on corner of one of them.
Currently looking to get the extended base set for them......
My standmounts would have fared better.
Reactions: Gray and Jasonovich
Maybe I should stick with my active standmount Elacs + sub. Maybe adding a second sub would be even better? Or is this another can of worms?
Do you have enough oooompfh from your SW?
Adding another just means you're getting OOOOMPFH instead of oooompfh 🙂
Might be worth it if it's lacking a bit in the low frequencies or false economy if you're already getting the desired outcome? 🙂
1. That's a decision for you to make!
2. Depends. Do you have a large room? Mine is pretty big and I've no issues with just one subwoofer. Plus, I have neighbours.
3. Needn't be. I've had floorstanders before and might get some active ones again in the future, but there's no pressing urgency for me just now. The current speaker setup's working a treat.
I started with stand mounts, upgraded a few times until I switched to floor standers , again making an upgrade, whilst the bass was plenty, it was becoming a bit overpowering for my room and listening was no longer enjoyable as I was missing the clarity and detail I prefer.
Maybe it's ok for some that can pull their speakers yards into the room, but many people can't.
I then switched back to a higher end stand mounts and have never enjoyed my music more.
My amplification has aways been of good quality, so I can't point the finger there. My current pre/power combo spec as below and the speakers sing beautifully, with sufficient low end for me
  • 2 x 710 watts @ 4 Ohms
  • 2 x 400 watts @ 8 Ohms
Of course, everyone's room is different, same for how people like to hear their music. The amount of cars on the road where all you can hear is boom boom boom, in someways says how many like to hear their music.
In my case stand mounts are preferable, if my room was significantly bigger, neighbours never existed, perhaps I would switch back, but from my previous experience it would probably need a significant amount of money spent on floor standers to better what I had before.
It all depends on the room.
Floor standers can excite room modes giving very woolly or boomy sound and therefore a bookshelf speaker is the way to go in that instance.
A subwoofer (Whether you have floor standers or bookshelf) is also a must, as it can be positioned optimally to improve bass without exciting room modes. (NOTE: You should not hear the sub only the speakers, but you will notice if you turn it off)
Bill
Not sure if it was already mentioned, but this site https://amcoustics.com/tools/amroc is a very good tool to calculate room modes, and than generate the room modes frequencies to experience the problems. It gave me lot of insights in this matter. However still not able to solve everything. We also have to live in this room...
If you're an apartment dweller you probably should stay away from floor speakers and subwoofers, you will piss off neighbors in a hurry, and could get evicted.
But if you own a separate home, meaning not a townhouse of condo, then to get the best sound floor speakers are the only way to make noise.
That's not to say there aren't some great sounding bookshelf speakers, but for the cost of those you can get superior sound from the floor speakers. Some wives will fight you over something as large as floor speakers, so there is that! Also some rooms are too small to carry what a floor speaker can do, so you have to consider the size of the room to get a better fit for speakers; even a medium size room with very large floor speakers won't work correctly.
Superior sound from floorstanders?
Interesting claim. I used to think that too. Mission 752s, Sansui AU-717 and the 217 amps, Marantz SA7001-KI. I loved this setup. Brilliant sound.
And if you need to shift a lot of bass, or to a degree, scale, then a floorstander is one way to do it. The Eggleston Works pair I heard recently were pretty damn impressive and see also the Alchris Audio and PMCs too.
On the other hand, standmount aren't short of talent either. They'll often image better, and aren't short of scale and dynamics especially in the larger models. Adding a subwoofer and trimming the sub's input to blend in rather than just bludgeon the overall presentation makes for an even more satisfying whole.
There's no right or wrong answer here. It's down to taste, preferences, available room size and budget.
Pound for pound? These days though, I'd take standmount speakers, active at that, and add the sub. Tremendous pairing.
I do agree with most of your points however when it comes to economics it often doesn't make sense.
You mentioned adding a sub to standmounts, well that and the price of decent stands added to the price of the standmounts will often push things into really good floorstander territory.
If you want to spend hundreds on stands that's up to you, they needn't be, but that's the world of price inflated accessories in the hobby.
Like I said, depends on what you want.
Ime, both can work very well.
I currently own a pair of Graham Audio LS6f (floorstanders) and a pair of Harbeth C7 XD (standmounts).
Both have great attributes in my room and I could happily keep either pair for a very long time. The Grahams have more obvious bass welly, but the Harbeths are better all round speakers. The midrange on the Harbeths and how they reproduce instruments and voices is just spectacular.
There are places for both floorstanders and standmounts and I don't think either one is better than the other once you reach a certain level. It is very room and preference dependent.
Both of these speakers, whilst different brands and types of speaker both share BBC lineage. Therefore I like both pairs, but for different reasons.
These are being driven by a very decent 400wpc amplifier, so I am giving them the maximum beans.
Therefore, back to the original post title. I disagree there is no contest between both types.
