New Dac the FiiO K13 R2R: Early Impressions
I am afraid all of those are probably above my pay grade but sounds an interesting proposition. At least I only have one system to listen to these days which is in my man cave and only use headphones.
That's why I am waiting to see if the K17 R2R has an improved R2R and Headphone amp in which case it would save a lot of space and mains leads/interconnects by replacing my four current units and the SSD I have in the Eversolo would transfer to a USB SSD caddy sitting behind. All theory at the moment!
I believe the K17 is already out but it isn't R2R, it uses AKM chipset, not unless they're bringing out an R2R version of the K17?
Now that would be interesting 🙂
@Jasonovich I meant to ask you before, I note from your diner set up you are using an LPS PL50 with your K11 R2R I assume? Did you detect any sonic differences with that?
Good question.
Yes small incremental but noticeable improvements to the sound. The bass appears to have better body, vocals more solid. Some may argue it's placebo but my ears tell me otherwise.
I would advise any one using cheap 12v AC/DC generic power supply, switch to a decent linear one.
The FiiO PL50 power supply is puka, not sure if this is compatible with K13 R2R, worth checking their website.
Good question.
The FiiO PL50 power supply is pretty decent, not sure if this is compatible with K13 R2R, worth checking their website.
Yes, quite possible, but don't quote that on ASR😡🤐
Fiio have produced another LPSU in a case which exactly mimics the K13 R2R with selectable 12 or 15V output - called "The Darkside" 🤦‍♀️ A bit obtuse!
I will not think about that until I am able to investigate the forthcoming K17 R2R though, as that has a built in LPSU and the K13 R2R at least has it's own SMPSU in a tin box internally!
I've had the K13 R2R for a month or so and really pleased with it.
I tried a Topping DX5 II first but it had too many bugs, tried to destroy my headphones/ears, and did not perform any different to any of my other DACs, so that was returned.
The K13 does sound different in a very pleasing way, more analogue and rounded without the sparkly harshness of the usual delta/sigma chips! Allows "non-defensive listening" - a quote I saw somewhere the other day, very apt I thought.
I do use it just as a DAC feeding my Topping L70 headphone amp via XLR out as I find this gives a little more dynamically compared to the onboard amp.
Eagerly awaiting the K17 R2R to be released, might be interesting/tempted especially as it is rumoured to have a more advanced R2R array, though this is not confirmed yet. I would love it if I was able to use just the single unit to replace my Eversolo DMP-A6, Topping L70/E70 stack and the K13 of course!
It's good to hear that you're really satisfied with your K13 R2R Dac. Incredible value, isn't it?
Yes it would appear so and looks to be a very decent build quality.
The only omissions for me are individually selectable headphone ports, instead of both, and an analogue input would have been useful.
I have not had a music session for about a week or so. Decided to have an extended one tonight.
Excellent, enjoying the music and did not have to tweak the volume down, or skip, on any of the former recordings I knew ( or thought I did) were harsh and very edgy ?
Why didn't someone tell me about R2R DACs a long time ago? 😀
Actually the resistor ladder architecture is fairly old. It was this type of DAC they put into cd players. The modern versions that have become so popular are much more accurate thanks to their state of the art "digital brain" (an FPGA).
I like the sound too. It simply didn't pair very well with my already darker headphones. At first i thought it lacked detail, but after a couple of weeks of focused listening i put it down to reduced brightness in combination with my headphones.
Definitely try the NOS mode if you haven't. That's where these DACs seem to shine.
I was not aware of that, very interesting.
I was not sure about the detail myself originally but as you say this is probably down to being less bright and what I call "tinselly" compared to the DAC on a chip variety. I already use NOS most of the time, with the occasional flip back to OS on certain tracks, but that usually does not last too long 😀
It's a shame that R2R is classed by some "experts" and reviewers as lacking - relying solely on detailed measured performance as the arbiter of pure sound. Obviously that comes into the equation but that does not necessarily tell you how good or bad it may sound to your ears!
I remember very many years ago, when I first got into the HiFI "merry-go-round" and started listening to some setups at various dealers and shows to some quite expensive gear, very often my initial thoughts would be that's offensively loud, too in your face, very bright or not musical!
That's why I always take even well respected reviewers claims that something is the "best thing since sliced bread" as a pointer that I may just want to listen to it and let my ears decide - and unfortunately they, like the rest of me, are showing their advancing years 🙁
Don't expect miracles from electronics. Year on year we may seen very small evolutions, if any... I recently compared the circuit diagrams of one of the latest Marantz amps with one of about 10..15 years ago. Almost identical. The main difference is in the housing of the amps. But lots of reviewers claim the new one sounds so much better. It would also be very strange if a reputable manufacturer suddenly knows how to develop better electronics when they are already doing that for decades....
And the same with DAC's. Every properly designed DAC should sound more or less the same. It shouldn't matter if you use R2R or delte-sigma of something else. If they clearly sound different than at least one of them has not been design in a correct way....
Personally from my research and listening the k9 is pretty much the sweat spot and pretty much the best thing fiio make, I prefer the akm variant with my ft7s. The THX amps really get the planners moving. The extra 150-170 is worth I think over the k13.
We are getting to the ASR stance of all DACs sound the same if the measurements are up to standard?
I fundamentally disagree because you are listening to different adoptions of similar chips AND their associated other audio circuits.
It just seems strange that an awful lot of people are saying the R2R DAC sounds more natural and analogue unless they have all been poorly designed of course and that explains it ?
In my singular experience with my first R2R DAC I find it far less fatiguing to listen to to - yes it may not be quite as detailed in the upper ranges but if that is the cost of not having harsh treble then I will gladly listen to it.
Hmmm, I heard those details with my B&W PX7 via bluetooth and Spotify (compressed) on my phone. Couldn't it be that you noticed it because you were listening to something new, so you paid more attention? Have you tried listening to the same music with your old equipment?
I have been thinking that more than once. Pretty much every time I went "oh, not heard that before" when listening to a well-known song with a new component. I then wondered if it were just because I was listening more attentively than I had done in the past ... And having a clinical lack of attention, it is definitely possible.
The only time I can reliably say it was a genuinely new level of detail was when I listened to the same song through headphones and immediately after through my speakers (which ofc immediately led me to splash out on a higher end pair of cans 🤣)
Reactions: nopiano
I'm not a science geek (quite the opposite - have had a Umik mic and REW sitting there waiting to be used for weeks 🤣), just very interested to learn more about this side of our hobby, but - if the treble is softer and the mids more pronounced - which I learned seems to be the case for when something sounds warmer, "more natural" etc.- shouldn't this be picked up by measurement? And ofc the implementation of a chip and the rest of the architecture should have an impact on sound but - once again, shouldn't this show up in measurements?
I’m not entirely sure I follow the idea of “listening harder” when adding new gear. For me, music always comes first. I play guitar myself, and I simply enjoy spending time with instruments. My daughter plays piano and has been learning violin at a high level with a member of CUA a folk band here in Ireland, so music is very much part of my daily life.
When I listen, what stands out to me is how things feel: if the bass becomes more defined and controlled, or if guitar strings seem to carry more weight and texture, then I take that as a sign the DAC is bringing me a bit closer to the original recording. To me, it’s not so different from how different strings or tonewoods change the character of a guitar.
When it comes to measurements, I’ll admit I don’t fully understand why certain details are or aren’t captured. I just know what I hear and what resonates with me, and I trust my own experience.
I also find it a bit puzzling when people strongly challenge what others hear in their own systems, especially if they haven’t actually heard that setup or been in that room. It seems more natural to respect that listening is a personal experience, shaped by context as much as by the equipment itself.
I completely agree, listening to music is a personal experience. I'm not a musician but in my former life as a Public Sector Accountant, I use to make music from figures! 🙂
It's nice to hear someone else echo that it's fundamentally a personal experience. The "music from figures" line made me smile and sounds like you brought some real creativity to the accounting world! 😉
At the end of the day, if the music is moving you and connecting with you in your own space, that's what actually matters. The gear is just there to serve that experience, not to become the main event!
Yes I totally agree and cannot explain why some people, lots of people actually, hear a different sound profile between DACs - especially R2R versus Sigma/Delta. So maybe the measurements commonly used are just not giving us the all the details to define sound quality? I don't have the foggiest idea.
There are those that criticise R2R DACs as a waste of space and very inferior to "normal" DACs yet there are many that prefer the sound.
What did actually amaze me that when I innocently posted my thoughts about my K13 R2R on a specific forum, I previously mentioned, I was inundated by extremely rude comments and suggestions labelling me either an idiot or that I should educate myself! When I stood my ground I ended up being banned (pass the tissues) which matters not one iota as I would not engage further in any case if that is the welcome you (don't) get!
I personally think the K13 R2R has given me a sound profile that I very much enjoy and has enabled "non defensive listening" - that is not tensing up or not reaching for the skip or volume controls when you know that some previously ear piercing screech or offensive harshness is in a particular track.
Sorry to hear about the insults you received, shouldn't be any place for that - it's just a hobby after all - but sadly this is the state of social media...
As per not hearing differences in DAC - again, don't know. Maybe with modern and "standard" DACs like AKM and ESS, as apparently all measure the same. But then almost everyone comments on ESS being brighter / AKM softer whatever so.... Who knows?
Hopefully not too much creativity. We know what creative accounting normally leads to 🤣
