altruistic.lemon said:Then surely all studio monitors must sound the same.
They should be similar but due to size and budget considerations they won't. Also some are designed for small rooms or close listening.
altruistic.lemon said:BigH, Interesting point. There seem to be those who think that all speakers do sound the same, only active ones, of course, and others who think it is the boom and tizz that someone (incorrectly) mentioned that applies to all passive speakers in greater and lesser degrees, which is why they sound different.
Practically, if all speakers could portray all the instruments they attempt to reproduce accurately, then all speakers would sound the same. For me the Maggies and electrostatics get the closest to reality, especially with some types of music. Standard boxes all suffer the limitations of electromechanical designs, obviously to a greater or larger degree. In the end there is no such thing, yet, as a perfect loudspeaker, and, while there isn't, there'll be argument about which gets closest.
To my mind the Yamahas aren't even close, but, as evidenced here, there are those who think they do..
BigH said:altruistic.lemon said:Then surely all studio monitors must sound the same.
abacus said:Studio monitors are normally near field and normally end up close to a wall or other surface.
Hi Fi speakers are designed for larger rooms with the user sitting quite a distance away.
Use a Hi Fi speaker in a studio environment and it will sound unnatural.
Use a Studio Monitor in a larger room and it too will sound unnatural.
Use a speaker outside its natural environment and it doesn’t matter whether it is active or passive, it will always sound rubbish.
I use passives for my Audio/Cinema system as it cuts down on cables; however for my Music and my PC, I use actives as they are more suited to the job.
As to the active/passive debate in the same type of speakers, then both have advantages and disadvantages and you just pick the one that suits you best.
Hope this helps to clear up the confusion that Hi Fi buffs seem to get into when actives and passives are mentioned. (Professional users just use the speakers (Active or Passive) best for the job they need to do)
Bill
altruistic.lemon said:BigH said:altruistic.lemon said:Then surely all studio monitors must sound the same.
i think you're right, but it means the accuracy of studio monitors is a bit of a myth. Certainly the speakers I heard sounded as different as the ones in the Hi Fi shops.
John Duncan said:Can I just say, davedotco, that I'm very much enjoying your contributions here. Thanks.
altruistic.lemon said:Nope, your first point, is, well, tosh, and your second doesn't bear scrutiny. Ah well.
davedotco said:Since such hackneyed old stereotypes were already being thrown around with such abandon I thought it appropriate to 'get that one in'.
Like many such sayings it has a strand of truth too it, many budget loudspeakers are still made that emphasise the mid bass to make up for a lack of real depth and lift the presence/treble region to give them balance. Nothing really wrong with this, it is simply making a budget speaker easier to live with, I was just making the point that there are other ways to make inexpensive speakers sound good without doing that.
the record spot said:davedotco said:Since such hackneyed old stereotypes were already being thrown around with such abandon I thought it appropriate to 'get that one in'.
Yes, strand being the operative word. Never yet heard "boom" or "tizz" coming out of any speaker uness it was on the soundtrack. A tired old cliche that deserves to get rebutted. Oh yes, I've heard a few actives as well some of which do a fine line in removing the life from the music - you can see why they need to be heard in the producer's studio and nowhere else...
davedotco said:I too have heard some pretty poor active speakers in my time, some quite unlistenable, but unlike some I do not jump to the conclusion that all actives are bad any more than I discount all passive speakers after hearing some of the rubbish that finds it's way into some dealers.
I have a background that encompasses both pro-audio and real hi-fi and find the entrenched and often quite absurd views on both sides of the devide quite amusing though the ignorance is often quite astounding.
the record spot said:Yes, strand being the operative word. Never yet heard "boom" or "tizz" coming out of any speaker uness it was on the soundtrack. A tired old cliche that deserves to get rebutted. Oh yes, I've heard a few actives as well some of which do a fine line in removing the life from the music - you can see why they need to be heard in the producer's studio and nowhere else...
Craig M. said:In response to the op, I've only heard 2 speakers/systems that compete with mine. One involved some massive (in size and price) Quad panels (can't remember the exact model) that sounded remarkably like my active monitors, apart from the bass which was bolstered by a REL sub and was way behind what I'm used to hearing. The other was the Avi ADM40s, the ADM40s were maybe a touch lighter in the bass but also a touch smoother, a very enjoyable sound either way. Avi aside, the only other active hifi speakers I've heard properly were some Adam standmounts (can't remember the model) and the Dynaudio Xeos, both of which disappointed me for the same reason - they lacked the sort of natural clarity I've come to associate with decent actives. Other than that, based on what I've heard so far, it would be studio actives all the way for me, for sound and value. Mine wipe the floor with any passive hifi speaker I've ever had or demoed in every department you care to think of. Bar looks!
SpursGator said:A couple of comments - first, no two speakers sound alike, and in fact it is/was something of an engineering challenge to get a perfectly matched pair from the same production line. The frequency response curve of any speaker, with all of its peaks and valleys, started as a razor-flat line of pink noise. There is not a speaker in the world - whether you call it a monitor or not - with a flat response. They are all completely different from each other.
Second, I disagree with the notion that a 'studio monitor' is necessarily flatter than a home hifi speaker. Manufacturers in both worlds must make trade-offs and thus choices at every turn. The oft-copied 'BBC monitor' speakers (Rogers LS3/5A et al) were famously not flat, but featured a dip in the midrange, as does a hifi speaker that became much-beloved as a monitor, the ProAc Studio 100. Engineers often are trying to hear the limits of what they are mixing and how hard they can push it, especially at the low end, and a speaker that shines a little light on the lower midbass can be helpful.
Third, there are different types of tizz-and-boom - or rather, different levels of sophistication. What I describe above, the so-called BBC dip, mirrors what people always do when they have cheap graphic equalisers - the smiley face profile. The bass and treble are boosted, the mid cut. This is the essence of tizz-and-boom - but some of the most refined speakers on the market do exactly the same thing. I will use ProAc as an example, since I admire and recommend this company all the time and don't want this to seem too critical. In despite having a big midrange dip, shows that maybe there are situations in which a little tizz-and-boom is a good design decision, despite its association with cheap speakers.
And as for all of the axioms being giving here in an attempt to define the difference between monitors and speakers, there is no difference - or rather, there are a wide variety of speakers from both worlds being used in both settings, with almost total overlap. They are all different and thus, it's a meaningless distinction even if we manage to make sense of it.
altruistic.lemon said:Which would you think better, though, active monitors, or active hifi speakers?
steve_1979 said:I agree. I've heard the Event Opals and they're shockingly good. A fair bit better than all of the passive speakers I've heard in fact. The only speakers that I've heard that were noticabilly better than the Opals are the Genelec 8260A and Quested V2108. I haven't heard the ADM40's but the old ADM9T's with the sub would probably give the Opals a run for their money too.
As for actives removing the life from the music... :roll:
IMO the clearer sound of a good pair of actives allows you to hear the music better which gives it more 'life' not less.
the record spot said:Yes and if you'd bothered to check my previous posts on actives, you'd know how much I really believe that. Not.
