tinkywinkydipsylalapo
- Jul 10, 2014
- 33
- 0
- 0
Vladimir said:Thompson you believe you can hear the difference between copper and silver cables due to difference in metal resistance at same gauge and length.
http://hyperphysics.phy-astr.gsu.edu/hbase/tables/rstiv.html
Silver - 0.0000000159 ohms per meter.
Copper - 0.0000000168 ohms per meter.
Wow... LOL!
dim_span said:Vladimir said:Thompson you believe you can hear the difference between copper and silver cables due to difference in metal resistance at same gauge and length.
Wow... LOL!
try it for yourself .... I heard differences on my previous system when switching between copper and silver speaker cables
use Prince's Purple Rain track and post here after you have tried the comparison
I could not hear differences when comparing speaker cables of the same type (copper vs copper and silver vs silver)...
until you have tried this comparison, you are merely 'speculating'
TrevC said:A bare wire on a speaker will work just fine as long as it doesn't short
tinkywinkydipsylalapo said:TrevC said:A bare wire on a speaker will work just fine as long as it doesn't short
No, it won't. You need two to complete the circuit. Or have you further refined your 'any cable will do' mantra? ;-)
dim_span said:until you have tried this comparison, you are merely 'speculating'
Thompsonuxb said:'believe'...????
Vlad, this is a pointless argument. I can sit you down and go through some cables via my set and let you decide for your self.
Vladimir said:Thompsonuxb said:'believe'...????
No problem. I'll send you my shipping address and you can send me any cable you want me to test.
Vladimir said:dim_span said:until you have tried this comparison, you are merely 'speculating'
Broner said:By the way, Vladimir, have you already watched Cosmos: A Spacetime Odyssey? I highly recommend it.
*yes, I know, this suggestions comes completely out of the blue.
Vladimir said:It seems like you guys want me to use my own money to prove you right. That is a bit unfair. I've accepted science to save me money spent on foo and if you want to prove to me that you spent your money wisely and it isn't foo, despite what scientific facts show, then it is only fair if you send me something to test at zero cost.
You can use scientific facts to prove to me that your cables are as brilliant as advertised, but you keep repeating 'try it, try it, try it'.
OK. Gimme!
dim_span said:then go Maplins (at your own leasure) and spend £6 (of your own money) on some speaker cable of the different metal that you currently own ...
dim_span said:then use the Prince CD and listen to Purple Rain .....
Vladimir said:dim_span said:then go Maplins (at your own leasure) and spend £6 (of your own money) on some speaker cable of the different metal that you currently own ...
I have a cable box. I've bought and DIYed cables for 2 decades. I simply do not hear a difference in unsighted tests regardless if they are steel, aluminium, nasty chinese 80% copper, audiophile 99% OFC copper, shielded, unshielded, braided, solid core, litz, whatever.
I recently replaced my Audioquest Type 4 ($80) with 32A rated solid core copper cable from a utility pole ($0). I don't hear a difference even sighted. I simply cannot be bothered about it anymore. But if you send me silver cables I'll make an exception.
ewwww...
dim_span said:And not only I heard differences, but so did my wife ...
TrevC said:Of course you need two wires.
dim_span said:you need to try silver vs copper ....
dim_span said:And not only I heard differences, but so did my wife and teenage son.
chebby said:dim_span said:And not only I heard differences, but so did my wife ...
This only counts if she was "walking in from the kitchen" at the time.
TrevC said:chebby said:dim_span said:And not only I heard differences, but so did my wife ...
The other day, upon a chair
I heard a difference that wasn't there
It wasn't there again today
Oh how I wish science would go away.
*yahoo*
dim_span said:taught science is often misleading .... My father's father was taught in science class that the earth is flat
I listen to music on my laptop that only has 2 speakers spaced 2 feet away from each other .... yet some of the sound/music seems to be coming from the centre of my laptop screen? Science also cannot explain that
dim_span said:I listen to music on my laptop that only has 2 speakers spaced 2 feet away from each other .... yet some of the sound/music seems to be coming from the centre of my laptop screen? Science also cannot explain that
tinkywinkydipsylalapo said:dim_span said:I listen to music on my laptop that only has 2 speakers spaced 2 feet away from each other .... yet some of the sound/music seems to be coming from the centre of my laptop screen? Science also cannot explain that
It's stereo. It's an illusion of solidity created by sound coming from two separate sources. TrevC will probably be along to tell us we're all being fooled.
