steve_1979
An interesting design that uses a similar co-axial midrange/tweeter driver to the 8260.
Good to see you back Alma. 🙂
davedotco said:steve_1979 said:ID. said:Yay. More living room friendly actives.
+1 This is good to see.
Dynaudio make some very nice sounding actives IME. Their actives have a similar 'house sound' to their passive speakers but tend to be a little bit clearer and go a bit louder before distorting.
Nice feature set, onboard dacs, eq etc.
Not cheap though, expect them to be the best part of £2k for even the smallest model.
emperor's new clothes said:davedotco said:steve_1979 said:ID. said:Yay. More living room friendly actives.
Onboard DACs? As with the XEO, they don't have any. There is an AD converter for the analogue input.
davedotco said:emperor's new clothes said:davedotco said:steve_1979 said:ID. said:Yay. More living room friendly actives.
http://www.enjoythemusic.com/cedia_expo_2014/part2/dynaudio_focus_xd600_...
Not according to this photo, spdif in (with link through) plus analog on phono.
emperor's new clothes said:davedotco said:emperor's new clothes said:davedotco said:steve_1979 said:ID. said:Yay. More living room friendly actives.
Yes, but stays digital all the way to the Class D output transistors., so no DAC required.
From Dyns newsletter:
The Focus XD also represents more than just a new high-end loudspeaker; it re-defines the
Hi-fi system itself: Focus XD allows a simplified audio system that merges high-end soundperformance with a new level of convenience, with only a music source needed.The Focus XD series, comprised of the compact 200 and floor-standing 400 and 600 models,provides a perfectly thought out solution for music playback: The digital music signal istransmitted losslessly from the source to the driver and without analogue conversion.
AlmaataKZ said:I am guessing in not so distant future most good mainstream sound systems including tvs, soundbars etc. will be dsp actives with room eq.
emperor's new clothes said:....Based on the Focus 160 @ £1800 going to be well north of £2k IMHO.
The XEO4 is >£600 more than the Excite X14........
davedotco said:steve_1979 said:Just contacted Teufel and they've arranged for a replacement. They said that it's not a known issue so fingers crossed they're right because I'd like to keep it because apart from this issue it's perfect for my needs in every other respect.
That's pretty decent service. Do let us know what happens.
steve_1979 said:davedotco said:steve_1979 said:Just contacted Teufel and they've arranged for a replacement. They said that it's not a known issue so fingers crossed they're right because I'd like to keep it because apart from this issue it's perfect for my needs in every other respect.
Their customer service is A1. They were always very friendly and helpful on the phone and there were no problems arranging replacements and a refund. They even arranged and paid for all of the couriers, all I had to do was choose the times.
It's a shame that the DecoderStation wasn't suitable as they are such a nice company to deal with.
davedotco said:steve_1979 said:davedotco said:steve_1979 said:Just contacted Teufel and they've arranged for a replacement. They said that it's not a known issue so fingers crossed they're right because I'd like to keep it because apart from this issue it's perfect for my needs in every other respect.
Was it the same issue as the first unit you tried, or something different?
steve_1979 said:davedotco said:steve_1979 said:davedotco said:steve_1979 said:Just contacted Teufel and they've arranged for a replacement. They said that it's not a known issue so fingers crossed they're right because I'd like to keep it because apart from this issue it's perfect for my needs in every other respect.
The DAC problem was the same as before but I could work around that by using the O2 as a DAC into the AUX inputs on the DecoderStation so that sorted that issue out. I'd have been satisfied if I could at least have used it as a simple 2.1 preamplifier.
However now that I have a subwoofer another issue reared its head! When I set the speakers to 'large' to allow the DM5's to play full range nothing comes out of the subwoofer. It won't let the subwoofer to play at the same time as when the main speakers are set to full range. The subwoofer only receives a signal if the main speakers are set to 'small'.
davedotco said:steve_1979 said:davedotco said:steve_1979 said:davedotco said:steve_1979 said:Just contacted Teufel and they've arranged for a replacement. They said that it's not a known issue so fingers crossed they're right because I'd like to keep it because apart from this issue it's perfect for my needs in every other respect.
Ah, I see.
When you set the speakers to 'small', what is the lowest frequency that can be set for the bass roll off?
Sorry, just interested.
steve_1979 said:davedotco said:steve_1979 said:davedotco said:steve_1979 said:davedotco said:steve_1979 said:Just contacted Teufel and they've arranged for a replacement. They said that it's not a known issue so fingers crossed they're right because I'd like to keep it because apart from this issue it's perfect for my needs in every other respect.
Ah, I see.
80Hz.
The DM5's sound their best when they're running full range though.
davedotco said:steve_1979 said:davedotco said:steve_1979 said:davedotco said:steve_1979 said:davedotco said:steve_1979 said:Just contacted Teufel and they've arranged for a replacement. They said that it's not a known issue so fingers crossed they're right because I'd like to keep it because apart from this issue it's perfect for my needs in every other respect.
Ah, I see.
80Hz.
That is contrary to my experience though of course not with DM5s. I know that this is AVIs default position, but I find almost all small speakers benefit from low frequency roll off, if bass performance is not compromised.
But then 80hz does seem rather high.
DocG said:C***! [Nor does the swear filter]
Bored? Me? Naaah!
matt49 said:I assumed there were three bass drivers, hence only one Xover needed. May be wrong about that.
steve_1979 said:Wersi Vocalis
[I have to drop the link, cos the spam filter doesn't allow it!]
Certainly a lot of speaker for the price. I'm guessing they must have scrimped on the quality in order to keep the cost so low.
DocG said:Would they be active? Or powered? The specs state '120 W RMS amp power'. How would that be split between the drivers?
steve_1979 said:The ATC SCM40's have gone active. *dirol*
I always wondered why they hadn't made an active version of them before. Apart from that new style grill these look absolutely stunning. Reasonably priced too.
http://www.whathifi.com/news/ces-2015-atc-to-introduce-scm40a-active-loudspeaker
