Posh ethernet cable?
Status
Not open for further replies.
I'll probably get slated by certain forum members for asking this, but is there a high quality eternet cable out there anywhere? I'm currently running one from my laptop into an airport express and wish to ramp up the sound quality.
hammill
212
You would be wasting your money. It would make no difference whatsoever. Hospitals, banks and air traffic control use standard ethernet cables - so should you.
Hmmm, not sure banks or hospitals are looking to improve their bass response, but hey, you never know
hammill
212
Cidershed:Hmmm, not sure banks or hospitals are looking to improve their bass response, but hey, you never knowBut it is essential that their data gets through 100%. Your bass is just digital data, same as the position of an aircraft over London.
scene
Moderator
Sep 25, 2008
789
187
19,070
Unless your pc is several tens' of metres away from the airport, then pretty much any CAT5 cable will do.
The questions you might want to ask are
- to what quality have I ripped my music? If it's not lossless, there is room for improvement
- what am I using to play my music? If it's straight to active speakers, then improving these may increase the quality, or if you're streaming it to an amp, could a Dac improve things?
JamesOK
86
Yep, agreed with Hammill, standard Cat cable, 1GB certified. Thats it.
My understanding is that just 1's and 0's flow down the millions of miles of Ethernet cable on our dear old planet.
As long as the devices at either end can produce and understand what is a 1 and what is a 0, in a timely fashion, that's all that matters.
So, buying expensive cat5 and patch cables may give you a warm glow and put a big smile on the retailers face. I have yet to be convinced it will make a difference.
But, who am I to question......
Best
Serenity
AlmaataKZ
295
I have seen references to expensive ethernet cables and I am sure you can buy one, but it would be wrong to expect any sound qualilty improvement. Here is an example. It may bring some improvement in terms of looks, but only you can decide if this is what you want to pay for, especially is that ethernet cables are normally hidden out of sight.
Advice (if you want any) is to spend the money elsewhere.
kena
104
JohnDuncan:You could always cut out the cable altogether and use wireless...
Ah but to ensure wireless quality pure Scottish Highland air is the recommended transfer medium
DistortedVision
217
39
18,820
I use Belkin Fast Cat5e 350MHz snagless. Its mostly because I like the snagless molded RJ467 hood.
http://www.netshop.co.uk/productcategorydetail.aspx?categoryid=53604
There's also 500MHz Cat6 if you so desire:
http://www.netshop.co.uk/productcategorydetail.aspx?categoryid=53955
Andrew Everard
1,878
AlmaataKZ:
Though of course while that cable may have the same RJ-45 plugs on either end as a standard Ethernet cable, it's not designed to conform to the Ethernet standard, nor indeed do its conductor pairs fulfill the same functions. Instead, it was designed purely as a digital audio cable, for use in Denon's proprietary Denon Link system.
interesting. I wonder if anyone has actually tried different ethernet connections as part of the music chain? From the answers here it doesn't sound like they have, plenty of responses talking about 1s and 0s being the same. In my experience cables make a significant difference.
Anyone got direct experience of different ethernet cables?
Andrew, saw those cables on a google search, £250 odd??!
Cidershed:
BUT CABLES DON'T MAKE ANY DIFFERENCE WITH ETHERNET!!! They can't. It's impossible.
I can only assume you have an association with a cable retailer? Sorry if that's blunt, but it's the only possible reason why someone would say there's a difference.
Rather than boring you with the technology, think about spotify. That comes through multiple routes to your computer, often changing paths to different cables minute by minute. Can you hear the difference? Of course not.
So is this more of the 'all cables sound the same' dross or is it specifically ethernet that exhibits identical characteristics regardless of materials and construction techniques?
nads:
Very politely put.
Yeah, sorry, it's my job (ethernet networks) and I do get exasperated at times.
Cidershed:So is this more of the 'all cables sound the same' dross or is it specifically ethernet that exhibits identical characteristics regardless of materials and construction techniques?No, it's someone who doesn't understand the technology. Please research ethernet, even on wikipedia, and you'll understand why everyone is right save one person.
Sorry but what's the difference between asking about ethernet cables and any other cable? By the way, has anyone slating the question actually tried any of what they are scoffing at? I suspect not lol.
Status
