Hi everyone, I need some help. I hope that I can get sound advice - pun intended
I bought an AVR from Onkyo which uses spring-loaded speaker-wire terminals. I'd like to use a 4mm thick (12 gauge) speaker wire, which requires the the addition of a banana pin to insert into such a terminal. However, in the photo you may see that there is in fact a strip of some sort that seems to be between the positive and negative sides. This is lapping over the hole a little, and blocks the banana pin from entering.
I am wondering what this does, and if it is safe to remove it entirely in order to fit the banana pins (NOT banana plugs) in there. Any help is much appreciated.
Thanks,
Rob
