davidf
Sorted!nopiano said:Maybe placebo will work, then!?
Just get the wife to say that while you were out she has sorted the 70Hz issue, hey presto, it's gone! Best answer so far nopiano 🙂
davidf said:Sorted!nopiano said:Maybe placebo will work, then!?
It's likely the long decay times and no so much the higher sound pressure. Which is the room characteristics, sadly.Vladimir said:I tried all wires I could find in my box-o'cables and it all sounds pretty much the same, the boom is still there unaffected.
Anyways. Thanks for reading.
insider9 said:It's likely the long decay times and no so much the higher sound pressure. Which is the room characteristics, sadly.Vladimir said:I tried all wires I could find in my box-o'cables and it all sounds pretty much the same, the boom is still there unaffected.
From what I've read the areas where there are differences in cable performance based on resistance are most pronounced where there are impedance extremes (usually dips). Otherwise the differences are minimal. But like I said earlier at that price you're not risking much.
I hear improvements from Kimber 8TC on just about any speaker. Can't borrow one any more, perhaps I should buy me one.ellisdj said:Sort out your one noter and you might start hearing the benefits in £200+ cables 😉
I don't live in the UK and I already have used one on loan from a mate, so I know it's good.ellisdj said:RA does 60 day returns 🙂
nopiano said:Sorry to read that it didn't work, and many thanks for posting those interesting graphs.
At the time, I didn't perceive too much change in overall response, as I mentioned above, but it just seemed smoother with DNM. I've still got the speaker wires somewhere, and would gladly post them to you if they might help. Does sound as though wires won't solve your problem though.
newlash09 said:I guess you are the most knowledgeable person to shed some light . I bought some supra ply 3.4 to be laid inside the flooring of my new home..I've never heard them
I've always used the cheapest cables I've found with good results. But those supras once laid..will connect the PMC's with the parasound halo..is there something IAM gonna miss in this combination owing to the cables...thanks to let me know please.
newlash09 said:That was very reassuring. Due to configuration of the room and my setup. Those two speakers cables for the L&R speakers will cross each other. Will this be okay...or will there be any sonic interference because of this.
steve_1979 said:Vladimir said:I tried all wires I could find in my box-o'cables and it all sounds pretty much the same, the boom is still there unaffected.
C'mon. Did you really expect cables to fix a boomy bass sound from your speakers/room?
Looking here, it suggests the 3.4s is screened, but not the plain 3.4. I'm not sure it matters at all, but I was curious so looked it up.Vladimir said:newlash09 said:That was very reassuring. Due to configuration of the room and my setup. Those two speakers cables for the L&R speakers will cross each other. Will this be okay...or will there be any sonic interference because of this.
Screened cable should have absolutely no issues. Good choice.
nopiano said:Looking here, it suggests the 3.4s is screened, but not the plain 3.4. I'm not sure it matters at all, but I was curious so looked it up.Vladimir said:newlash09 said:That was very reassuring. Due to configuration of the room and my setup. Those two speakers cables for the L&R speakers will cross each other. Will this be okay...or will there be any sonic interference because of this.
http://www.supracables.co.uk/speakercables/spkrply.html
We had better not tell newlash then!Vladimir said:nopiano said:Looking here, it suggests the 3.4s is screened, but not the plain 3.4. I'm not sure it matters at all, but I was curious so looked it up.Vladimir said:newlash09 said:That was very reassuring. Due to configuration of the room and my setup. Those two speakers cables for the L&R speakers will cross each other. Will this be okay...or will there be any sonic interference because of this.
I wouldn't be able to sleep at night.
Hmm couldn't figure out how to DSP google chromecast audio.Gazzip said:Would you not just DSP its ass out of your room? Glad to hear you are moving back to hi fi from head fi.
Roger Russel writes clearly and in detail. I've seen various articles before. He is essentially an engineer type and therefore a cable sceptic. I think I'm veering more his way as I age, but presume my reducing hi frequency perception might be to blame!Vladimir said:Hmm couldn't figure out how to DSP google chromecast audio.Gazzip said:Would you not just DSP its ass out of your room? Glad to hear you are moving back to hi fi from head fi.
BTW more good info on how inadequate speaker gauge can affect sound available here.
nopiano said:Roger Russel writes clearly and in detail. I've seen various articles before. He is essentially an engineer type and therefore a cable sceptic. I think I'm veering more his way as I age, but presume my reducing hi frequency perception might be to blame!Vladimir said:Hmm couldn't figure out how to DSP google chromecast audio.Gazzip said:Would you not just DSP its ass out of your room? Glad to hear you are moving back to hi fi from head fi.
