007L2Thrill:MUSICRAFT:007L2Thrill:MUSICRAFT:
007L2Thrill:
Interesting thread! I'm saving at the moment and will be buying my new speakers in the next couple of months, what's on my shortlist is MA RX6, B&W 683 and KEF Q700, would anyone care to elaborate on the strengths and weaknesses of the different speakers.
I will of course have a demo when the time is right, but I am just curious what others thought?
Rick@MUSICRAFT how would you rate the 3 speakers I have listed.
Thanks a lot!
Hi 007L2thrill
I would say from these three speakers Monitor Audio's Silver RX6 speakers are easily at the top followed by the Q700's and then closely by the 683's. Some of the qualities of the Silver RX6's include having an excellent mid/treble performance (without being in your face or upfront), a powerful bass (without boom & wobble) and an overall far more coherent performance.
The Silver RX6's build, fit, finishing, presentation, performance and pricing simply adds to a pair of speakers which excude class.
Monitor Audio inspires confidence
All the best
Rick @ Musicraft
Hi Rick
Thanks for that, helped a lot.
A lot of people I have spoken to and dealers I have emailed have said monitor audio RX6 as the best speaker, so that's on top of my list now.
One last thing if I added in the B&W CM8 would you class these better then the RX6.
Thanks again Rick.
All the best.
Mike.
Hi Mike
Your welcome.
This is beause the Silver RX6's are superb. The RX6's speakers simply excude class and also fully deserve the praise which they receive.
As for the the CM8's you might also want to consider the Silver RX8's as these are also at a similar price.
From your choice of speakers i feel the Silver RX speakers is more likely to ultimately give you long term satisifaction.
All the best
Rick @ Musicraft
Thanks Rick.
If I did get the monitor audio's I would get the RX6's as then I would have the funds to be able to upgrade my AMP too.
All the best.
Mike.
Hi Mike
Your welcome.
If you did go for the Monitor Audio's and still have the funds available then i will suggest in the first instance you should look at putting the money towards completing the Silver RX set by gradually adding the RXLCR, RXFX and RXW12 as this route will give you a far bigger return on your investment then changing the amplifier. Your TX-SR875 is still good enough. A combination of the TX-SR875 and Silver RX6 AV12 package is a combination which i am sure you will enjoy for many years to come
All the best
Rick @ Musicraft
