AlmaataKZ said:Thanks! Which of these do not have remotes?
John Duncan said:If you're going to put all these pictures in, can you change the width to 400 and leave the height blank? Makes the page load a bit smoother...
AlmaataKZ said:Focal - pro and 'kinda domestic looking' models as well as a recent nice compact XS speaker
http://www.focalprofessional.com/
www.focal.com
John Duncan said:The_Lhc said:You mean 2? Not sure that's quite the definition of plenty.
When 3 = many, maybe it is.
shooter said:![]()
Pure extravigance!
Kyron Gaia. 3 Way, DSP Controlled Active Dipole Loudspeaker.
Frequency Response Range
20Hz to 30KHz
Polar Response Pattern : Figure 8 response
Tweeter
4x 1 inch ring radiator with patented symmetrical drive motor
Midrange
4x 7 inch neodymium dipole midwoofer
Woofer
12x 12 inch dipole long throw woofer
Preamplifier
Inputs S/PDIF, AES/EBU, Balanced XLR, Unbalanced Eichmann RCA
6x Digitally controlled analog volume control
Digital Signal Processing by DEQX™
High Definition Speaker Correction
Linear Phase Crossovers
Advanced Room Measurement and Correction
Amplification
High - 2x 200 Watt amplifiers
Mids - 2x 500 Watt amplifiers
Subs - 4x 250 Watt amplifiers
Total amplifier capability including headroom - 5000 Watts RMS :twisted:
Phileas said:John Duncan said:The_Lhc said:You mean 2? Not sure that's quite the definition of plenty.
Im not sure you're cut out to be a moderator John ...
shooter said:![]()
Free 2 way active transmission line. [Designed by PMC]
The Free loudspeakers has an internal void within the cabinet, and a number of connections for a Wi-Fi unit (such as a SONOS™ ZP80s or Apple™ Airport Express). Internal connections allows a Wi-Fi unit to be installed within the speaker and connected to the internal amplifier providing a single channel of audio per speaker. Wi-Fi can be added to both speakers for a complete wire free setup.
shooter said:![]()
Pure extravigance!
20Hz to 30KHz
Tweeter
Midrange
Woofer
Preamplifier
Amplification
AlmaataKZ said:shooter said:![]()
:twisted:
Whoaaaaa! Monster of a speaker! Is there a website? Looks like scanspeak mids?
AlmaataKZ said:Linn - domestic only
www.linn.co.uk
Linn does some models in active, but as far as I know some are only possible with external crossovers and power amps. All are very expensive.
http://www.linn.co.uk/systems/products/loudspeakers/klimax-350
AlmaataKZ said:shooter said:Free 2 way active transmission line. [Designed by PMC]
Very interesting. Is that a current model? Link? What sort of price? Power?
shooter said:AlmaataKZ said:shooter said:![]()
:twisted:
Not sure on the drivers AlmaataKZ and website linked below, lots of info on there.
MattSPL they're $160'000 Australian Dollars
http://www.kyronaudio.com.au/
