Overdose said:Ajani said:To be honest, neither the Lyndy nor Cyp (which I also assume are the same product) seem appealing. I usually find that products loaded with extra features + striking cosmetics + a fairly low price do so at the expense of quality. The 3 star review of the Lyndy in WHF confirms those suspicions for me.
I wouldn't have any problems with sound quality with regards to the price, the price of £350 is not cheap for any DAC and much cheaper audibly transparent DACs can be had for much less. In fact the price is similar to other DACs of comparable design, ie DACmagic Plus and Matrix Quattro DAC. Spending this sort of money should really get you more than just a DAC anyway.
The ratings thing would also not put me off. It would be interesting though, to see independent reviews of both items, though I suspect that reviewers might need to be careful to remember what they wrote about one of the items before penning the review of the other. 😉
The_Lhc said:Well, you're an optimist, I'll say that much for you...
James7 said:Yes, i know what you mean, steve_1979, but the Advantage does contain the power amplifiers for the Kensai so you feed the signal via interconnects from a preamp just as you would any normal active speaker. In a way it's an active floorstander but with separate enclosure for the tweeter and midrange unit. As you say, an interesting design, even a strange one. I have heard the Kensai though, and as a passive mini monitor it is very effective. In its active floorstander form, though no idea
Ajani said:...I've also found little difference (other than frequency response) between my Squeezebox Classic and an Emotiva XDA-1 DAC.
steve_1979 said:Ajani said:...I've also found little difference (other than frequency response) between my Squeezebox Classic and an Emotiva XDA-1 DAC.
Really?
I would have thought that all audio DACs are capable of reproducing all frequencies with the audible range (20Hz - 20kHz). Which part of the frequency range do you think isn't getting reproduced by one of your DACs?
Ajani said:steve_1979 said:Ajani said:...I've also found little difference (other than frequency response) between my Squeezebox Classic and an Emotiva XDA-1 DAC.
Really?
All of the range was being reproduced. It's just that the Classic seemed warmer and the XDA seemed bright. In either words: neither seemed to have a neutral frequency response (which I would assume is deliberate for whatever reason).
morgan said:Could you please add us to your list of manufacturers. Morgan Audio Systems Ltd. Thanks.
skippy said:Thinking about pairing up a set of either dynaudio, genelec or Adam's to a sonos connect using xlr to rca cables.
How would the volume be controlled? Would you set the volume to 11 o'clock on the speaker and then just use the app to alter the level.
Not heard any of the speakers above, but I'm more than happy with my aging dynaudio audience 42's
skippy said:Just had a look on the Roland website.
Slightly different setup than I was thinking. Basically what I'm asking is if the speakers could be controlled remotely or is there a manual volume control on each speaker?
They'd probably be the bma6 mkii's too.
Thx
