Tarquinh:AKL:
Tarquinh: Easy - equipment upgrades are the answer, and might just work out cheaper. I'm always puzzled why people seem to spend a lot of time and money fussing with bits that, if they do improve the sound, do so marginally whereas addressing the part that makes the most dramatic change, the components, gets somehow forgotten.
That is true up to a certain point.ÿÿIt would cost considerably more than the costs of mains cables/conditioners to replace components and materially improve the sound of an expensive system (worth say more than £3.5K).ÿÿThe laws of diminishing returns kick in and the more you spend, the less improvement you get back proportionally speaking. So a lot of people spend a few hundred pounds to wring the most out of their system, rather than spend moreÿthan a thousand pounds to replace a component (assuming the law of thirds apply).ÿ This is even more true as you go up toÿmore expensive systems of over £5 to £6K.
But it is all about proportionality, hence it would not make sense spending £500 on mains cables/conditioner to try to improve a £1.5K system, much better to switch components, especially speakers which tend to make the biggest difference in terms of improvement vs costs.
AKL, I'd love to agree with you but the problem is that sonic benefits if any of mains conditioners and mains filters remain highly debatable.
Even if there were benefit from conditioners or cables, ÿI ÿstill don't think that a system over a certain price would benefit more from adding a mains conditioner or a mains filter than it would from changing your amplifier or speakers. Taking your own system for example, I'm fairly certain you'd notice a bigger difference if you swapped your amplification to Naim, Unison Research or Primare, or if you changed your Spendors for Sonus Faber at or above the same price level than if you added a mains conditioner. Upgrades don't necessarily have to cost more, either.ÿ
As to power cables, I'll leave it to Bryston:
"When you plug your power cord into the wall outlet you are in 'SERIES' with all the wire on the other side of the wall all the way back to the power source. The small length of power cord from the wall to the amp is insignificant compared to the miles of wire it is connected to. As long as the power cord can deliver the current and voltage required to drive the amplifier to full power it is as good as it can get."ÿÿ
As I've said on numerous occasions now I noticed a significant improvement when I added a Nordost Shiva to my system which already had a Merlin Tarantula on it. So much so that I then spent a further sum on 2 Clearer Audio Silverlines with upgraded plugs. Now that means I'm either mad, stupid, deluded or pleasantly surprised. Given that I could sell all 3 cables on and realise £400 (ie get my money back, or I could keep them...and I've chosen the latter, it must say something.
ÿ
