I am just finishing a home demo of Yamaha Z11 which I have been offered for £3300.00 as an ex-dem
It was very difficult to set up and the auto setup is useless in my view as it cut all high frequencies on my left channel on one EQ setting, and all low frequencies on another EQ setting which took ages to discover as I initially thought my speaker was faulty then I tought it was the amp.
I have it working fine now and it is very good , just needs some fine tuning on EQ but before I purchase.
What would members views be between the two amps?
The only shorfall I see with the Arcam is if you bi-amp ,which I do, you are then reduced to a 5.1 amp
looking forward to your comments
Regards
Andy
Regards
Andy
