Upgrading speaker cable - worthwhile?
CarlDW
23
I have recently purchased a Yamaha MCR140.
Would an upgrade to the standard bare wire speaker cable improve the sound in any way?
I would be looking to spend £3-£5 per metre.
Thanks.
1984cw said:
Thanks.
If it's really thin, then yes, but yu don't need to spend much to acheive 99.9% of what you ever will IMO.
I personally would recommend Van Damme studio grade 2.5 mm Check prices but it's available for around £2/m if you look around.
Thanks for the replies, I think I will invest a small amount and give it a try.
I have been very impressed with the Yamaha so far, it sounds good and the wireless transmitter for my iPod Touch has made my life so much easier!
Try some of this stuff:
http://exceptional-av.co.uk/product.php?fdProductId=221&gclid=CPCjg-PAra0CFSFItAodW1EX1A
Not that I know what I'm talking about. 🙂
Happy new year and welcome to the forum
Cno
