BigH said:Sospri said:Covenanter said:Sospri said:Covenanter said:Sospri said:Covenanter said:I read on the Naim forum that the fuses they recommend, you know the 13 amp ones that their equipment can't possibly need, are directional, ie they work better one way round than the other. I wonder if you have your fuses in the wrong way? Possibly you live in the Southern hemisphere as I read the fuses work the other way round there.
Chris
PS If your problems persist I can recommend a good exorcist.
PPS Have you thought about a divorce in order to get a room where you can have the equipment you truly desire? Financially it's really bad news, trust me I've been there, but nobody can gainsay me if I want to house my speakers in baths of liquid nitrogen or whatever the latest idea from the hifi loonies is.
As you say you read that on the Naim forum, not stated by Naim.
You will get loonies everyware, there are loads on this site................
I believe it was posted by the forum Administrator but I don't know if he works for Naim.
Chris
Ah so a certain make of fuse was not recommended by Naim, I do wish people would get their facts straight before they post lies.................
" ... the equipment does seem to sound better with the fuse fitted in a particular direction (see post in the FAQ). Strangely it seems the opposite orientation sounds best in the Southern hemisphere. " - Naim Forum
So what kind of "lie" is that?
Chris
Can you tell me where Naim as a manufacturere recommends a particular make and direction of fuse as you were referring ?
It on here: http://forums.naimaudio.com/topic/equipment-fuses
NAIM AS A MANUFACTURER.............jeez.
