Suggested Interconnects for the 5.1 output of a Sony BDP S760 Blue Ray Player into an AV Processor
Selby
16
Hello everyone! First posting here, Ive just gone ahead and purchased the sony BDP-S760 Blue Ray Player to go with my existing Home cinema setup (Arcam FMJ AV9 Processor and 3 FMJ P35 Amplifiers). Existing cables are VDH Revolution Hybrid Speaker cables and same as interconnects from the Processor to Amplifiers concerned.
My question is: what 5.1 cables would be good from the output of the Blu Ray Player into the FMJ Processor. Should I stick to the VDH  brand and opt for (say) the first ultimate's or perhaps Should I start saving for some more Revloution cables to be made up as single ended interconnects. If I go the latter route then its quite clear that the cables are more costly than the Blue Ray itself!!!!!
Any thoughts? I just want the best that this BD unit can possibly output.
Speakers are XQ50c for Centre and Kef 3005 for Surrounds and an MA FB212 Sub with a 40X2000 Sony LCD.
hi there,i got a set of monster 5.1 interconnects from e bay and they are good quality if that helps
Hello, I like the idea to use all VDH cables. I would buy the VHD the Wave because these are very fine and if you ever make the upgrade to another processor chances are that more expansive cables will become obsolete.
