psurquhart said:Whats the difference between Premium and Ultimate ?
Jason36 said:Also I believe that only certain tracks stream at the higher bit rate......hence why I believe it says "up to".
They may have changed it since I upgraded to premium 6 months ago.
psurquhart said:Jason36 said:Also I believe that only certain tracks stream at the higher bit rate......hence why I believe it says "up to".
Still want to know how you can tell what is or isnt the higher bit rate stuff ?
Anyone ???
fr0g said:And I assume by "ultimate" whatsisname means "unlimited". The difference is that with premium you can install on phones and tablets / play through media players, and you get the high bitrate.
domenn said:and do you have gapless playback ? :rockout:
CJSF said:fr0g said:And I assume by "ultimate" whatsisname means "unlimited". The difference is that with premium you can install on phones and tablets / play through media players, and you get the high bitrate.
Hay 'Kermit' . . . I presume you mean me, the name is not difficult . . . 'CJSF' . . . sorry my dyslexic brain got things mixed up again, I mean 'fr0g'.
CJSF
