TrevC said:
davedotco said:
TrevC said:
davedotco said:
TrevC said:
davedotco said:
TrevC said:
CnoEvil said:
TrevC said:
CnoEvil said:
SiUK said:
I think you are confused, fr0g.
Don't you know the facts yet about putting a system together - Get a very cheap digital source (as they all sound the same); then get a budget amp (as they sound very similar to expensive amps); put 80% of your budget into speakers (as this is all that matters); wire it with the cheapest copper you can find and feed it low bit rate (as all bit rates sound the same); avoid vinyl at all costs.
There is no need to audition, as this is too confusing....all you need is a spec sheet.
If the whole thing is too much effort, go Active. :twisted: :shifty:
A budget 60 watt per channel budget amp (that meets specification) with vanishingly small distortion is going to sound exactly like a premium priced one. How could it possibly be any different?
Also a budget digital source is going to distort the sound far less than even the best speaker in the world.
If you say so.
Can you give examples of budget amps that you've heard, that have sounded like premium ones that you've heard?
Have you ever listened to a DCS (multi box) CDP or a Linn Klimax DS and compared them with budget offerings?
The difference is in the way the amplifier handles itself when operated close to and sometimes just beyond its 'limits' which happens a lot in real world situations.
I guess that if the written specifications were more complete and measured what happens in difficult situations they might tell you what is going on but I have never, ever, seen a written spec that comes anywhere close to that.
When Alan Shaw issued his now famous "Harbeth Challenge" he was at pains to point out that the amplifiers under test had to be working 'within their design parameters' something that is very often not the case in the real world.
So, when using a budget amp or a premium amp "within their parameters" they won't sound any different, which is the point I was making.
in the case of power amplifiers you are correct, integrated and pre-amplifiers can, and often are, deliberatly 'voiced' to sound differently so differences can be heard.
However this slightly sidesteps my point, which is that in an awful lot of systems, amplifiers and not just budget ones either, are not being used "within their parameters" and it is the way amplifiers behave under those conditions that makes the difference.
Naturally in an ideal world amplifiers would never be used in that way but the reality is that they are, and with the current trend for matching budget amplifiers with more demanding speakers this is becoming more common.
To "voice" a preamp would require some deviation from a flat frequency response, so I don't really agree with you on that point. Line level signals don't usually need any preamplification, so a selector switch and a pot will suffice.
Obviously using inefficient speakers on an underpowered amplifier won't sound good, but I'm not talking about that.
There are all kinds of ways an amplifier can be voiced without deviating from a flat frequency response but that is difficult to prove without actually showing how it can be done.
The power issue is, in my view, much more of an issue, I accept that a lot of modern music has a very limited dynamic range but when dynamic material is used, nominal 60 watt amplifiers can find themselves in distress very easily indeed, and not just into difficult speakers either.
Name one way to voice an amplifier without altering frequency response.
How about 300w? Only £150.
http://www.behringer.com/EN/Products/A500.aspx
Looks horribly cheap, but will fool an audiophile easily.
http://matrixhifi.com/ENG_contenedor_ppec.htm Also check out the interconnect and "rack".
Phase response, distortion spectra, transfer charateristics, dynamic power response, the first two are most common, the second two power amp 'tweaks'.
The Behringer is 300 watts, try the same test with a 60 watt budget amplifier, as per your original claim.
Look trev, I agree with an awful lot of what you are saying so do not want the argument to go on, lets just say that whilst I agree with you in theory, in the real world a lot of common amplifiers are underpowered and have poor control over a lot of speakers, many of them supposedly easy to drive, hence the 'brightness' and 'boomy' bass issues that are so common on here.
I guess you could say that the amplifiers are not operating correctly and whilst this is probably true, this is how they are used much of the time and the reality that, as a dealer, I saw all the time. Given the current fad for pairing budget amplifiers with more expensive speakers I doubt if this issue is getting any better.
