Mains cables ?
CnoEvil
556
14
Some say YES......and some say NO.
You need to try one for youself from the likes of Clearer Audio, where you get a good trial period....or from your local dealer.
Covenanter
88
34
18,570
No, but you can convince yourself that they do. £80 will buy you a couple of bottles of decent wine. Have the wine and then you current cable will sound wonderful.
Chris
MattSPL
19
I have found they make a difference, but some of the so called Hifi mains cables are just spruced up standard cables with a fancy sheath covering them, and better quality plugs. These are not going to make much difference, yet sometimes cost £100. This is one reason why some people think mains cables are voodoo, because they have never tried a specialist, purpose built cable.
Wireworld and Nordost are 2 manufacturers that spring to mind. They both make specialist Hifi mains cables, and these can make a significant improvement to your system, but they can cost a lot.
I personally rate proper Hifi mains cable above speaker cables and interconnects. I gain greater benefits from Mains cables.
Macspur
843
I'll be trying out an Audience AU24 later this week, at a knock down price, normally £1200 new!
Have previously tried a Cardas Golden Ref and there were definite improvements...
Incidentally have tried a £5 bottle of wine and a £95 bottle... couldn't tell the difference!
I know what I'd rather spend my money on and I can assure you, only if I can hear a marked difference.
Mac
MattSPL
19
Also, if your going to spend money on mains cables, change the fuse in the U.K plug too for an Audio grade fuse like Hifi Tuning. And then change the Ac fuse(if accessable) in the equipment.
abacus
Make sure you do the test blind, (So that you have no idea which cable is in use) and you will find that there is no difference between cables, so you can stick with what you have.
If you want to hear a difference, make sure you know which cable is in use and your brain will tell you that they sound different, (Even though they don’t) it’s just a normal human failing where other senses override your ears. (Hence the blind test is best as only your ears are in use)
Hope this helps
Bill
Ben K.
54
Try one on 60 day trial from clearer audio. If it sounds better and justifies the price to you buy it. If you hear little or no difference or don't think it warrants the cost return it for a full refund. Simple!
Covenanter
88
34
18,570
I'm willing to bet that none of those who suggest that changing your mains cable will make a difference can put forward any logical explanation as to why that might be the case. I'd also suggest (ducks) that none of them has any scientific qualification.
Chris
davidpr
7
A really good April fools!
Joshuamessenger
11
Might give the 60 day trial ago with the cable, personally I can't see how it would change the out put of the amps signal but for a risk free trail, it's worth the time for the possibility even a slim one for improved sound quality. .
Benedict_Arnold
661
Chris
Wine???
80 quid will buy you a couple of bottles of decent malt whisky (or Irish - but God forbid American - whiskey even). Then your hifi will sound sublime :cheers:
Benedict_Arnold
661
BTW IMHO the only things a mains cable needs are 1, to have a 13-amp plug on one end; 2, the right kind of plug on the other end; and 3, to be long enough to make it from the wall socket or surge protector to the hifi. The key thing to do is to keep your mains cables away from your audio cables so you don't get any mains "hum" being picked up.
Joshuamessenger
11
to your description. what I got ATM dose its job fine
pauln
137
I generate my own electricity from solar panels. The AC produced has a much cleaner wave form than what you get off the national grid. Don't let anyone tell you that you need to pay ridiculous amounts of money for audiophile solar panels - any type will do the job just fine.
ID.
207
What do you do at night ;)
I've seen battery power packs marketed for audiophile use, but then I guess being a battery it would make no difference whether you charged them off solar panels or the grid.
I'm looking into a hydroelectric system myself, but I don't know what to do about the disturbance caused by the constrant flushing noises.
gurjitsidhu
61
I would spend the money on a monster mains cleaning adapter instead and you will have all your sockets cleaned from any mains interference. Rather than just getting one main cable
DIB
166
36
18,620
The only way to know for sure is to try yourself.
Last year I dabbled with mains leads and blocks from Mains Cables R Us, and also a SBooster for my Squeezebox Touch from Mark Grant Cables. I went into it with an open mind, trialled them for the 30 day period and decided that I could hear no difference so I returned them for a full refund.
Both these companies are superb to deal with and offer a no quibble returns policy provided you return their products in pristine condition.
I would never knock anyone for saying they find an improvement, but personally I could not.
relocated
74
:rofl: :rofl: :rofl: You are actually a day late, never mind an excellent hoot.
