Mains cables ?
If you don't believe mains cables work, or won't even try them, that's your loss.
wireworlds cables are unlike other power cables in design. They have been designed to act as a filter, much like a passive mains filter in an extension block. Mains electricity operates at 50/60hz, the wireworld cables have been made to filter out noise in this frequency range. So, although wireworld are unique in their design, there's your scientific explanation.
Best to try some out, probably depends on your wiring, some find fancy cables make their system worse, read comments like sucks the life out of my amp.
Found that with a tacima trailing socket, not a problem with my regenerator or Mains conditioner though.
Is this an April Fool post? If not I assume you meant they are designed to filter out noise outside this frequency range, if not they would filter out the power itself.
However, as I've pointed out endlessly, there will be a bloody great electrolytic capacitor in your equipment's power supply that will filter out any high frequency noise that gets to it so, whilst I'm in favour of having the cleanest possible power coming in, it's hard to see that removing something in a cable, assuming it works, that will be removed a couple of inches later in any case is going to make any difference.
Chris
PS Interesting that their website declines to say what "scientific principles" make the cables work.
you mean this?
http://www.wireworldcable.co.uk/unique_design.html
Sorry to disagree, but I can't see any science on that page at all, just lots of TM's indicating they've made something up...
Make sure you upgrade the likely 20 meters of standard 2.5 TPS cable that the electrician put into the walls between your consumer unit and the socket too. That needs to be audiophile quality!
Seriously, do you really think that after the electricity travels all the way through countless wires and connectors of varying quality and age to reach your wall socket, the last 3 feet are going to make any difference?
It's the audiophile equivalent of boswelox.
Only if you have hi fi quality fuse in the plug!
MattSPL said:
I have found they make a difference, but some of the so called Hifi mains cables are just spruced up standard cables with a fancy sheath covering them, and better quality plugs. These are not going to make much difference, yet sometimes cost £100. This is one reason why some people think mains cables are voodoo, because they have never tried a specialist, purpose built cable.
Wireworld and Nordost are 2 manufacturers that spring to mind. They both make specialist Hifi mains cables, and these can make a significant improvement to your system, but they can cost a lot.
I personally rate proper Hifi mains cable above speaker cables and interconnects. I gain greater benefits from Mains cables.
+1
I use the wireworld sliver cable from my mains coniditioner to my amp.. I have tried so many but none IMHO are anywere near as good. It does not kill dynamics, actually increases it. No sign of brightness at all... expensive.. but wireworld mains cables work..
+1
Looks expensive, 1 m is £377.
+1
yes thats about right. I buy stuff course i want to improve my listening pleasure. Not for the sake of buying good looking cables or boxes.. I dnt do traditon, I do what my ears tell me sounds good. Even with a cables at that high a price it made more sense to me than actually do any other upgrage. The cable was on a 60day trial period no questions asked. Even at that price its a really nice cable & then some.
Motorcycle "snake oil" salesmen will try and sell you "blinker fluid"...
Motorcycl
pauln said:
I generate my own electricity from solar panels. The AC produced has a much cleaner wave form than what you get off the national grid. Don't let anyone tell you that you need to pay ridiculous amounts of money for audiophile solar panels - any type will do the job just fine.
Solar panels are so passe' :shame:
Living only 40 or 50 miles from NASA, we're all already using dilithium crystals.
Now, when the flux capacitor finally arrives, and I can actualy get the De Lorean to start, I can fast forward to 2023 and get the new DAC-XP on Fleabay used for about five bucks.... 8)
Native_bon said:
+1
So you have only 1 for the amp?
Anyone searching for an example of expectation bias need look no further than this thread.
In a past life I designed audio recording equipment for a well known national broadcaster. At no stage did we entertain any cable tomfoolery, except to specify current carrying capability for mains cables, and basic LCR parameters for signal and speaker leads.
In spite of this, we still managed to build studios which arguably produced some of the best recordings of the 20th century. Just remarkable how we managed to get by without the benefit of modern marketing.....
hi all ,thought i will say over the years of the quest of improving my hifi i have found that mains cables do make a diffrence,over the years i have used, russ andrews mains, clearer audio mains,nordost,mains ,shunyata mains,locus design mains,and the one i use now xlo limted ,which have brought the best out of my system,if they did'nt work why would i bother. im not saying that it works for everybody,but lets not make a decision for someone else,let joshamessenger decide for himself.cheers david
Native_bon said:
Yes Course I think thats were thier cables make the most improvment in sound.
Just thought you may have some others on the dvd and dacs.
Have you tried Clearer Audio?
Hum... What of ..WIFI.. internet.. sky.. virgin satellite... not to talk of more equipment in ever house. In one home you may have as much as four laptops or even more phones. The noise in the mains these days will not be the same like the time you mentioned.. I think you need to kind of bear that in mind..
I have ordered an upgrage for mains of my Audiolab M-dac.... The oppo 105 is very particular able mains cables... It seems not to like them for some reason.. The original cable with the oppo 105 sounded much better.
Absolutely, there was someone earlier that seemed to think paying £80 for 2 bottles of wine was an excellent way of spending that sum. Now that really is 'expectation bias'. :O
Strangely, in the 30 years since I was an EE, the basic theories of electromagetic radiation and conduction have remained the same. In fact, they haven't really changed for the last 100 years.
As long as your amp has some filtering on the mains input (a power supply transformer and storage caps make a pretty good filter), then no amount of nonsense with a mains cable will make any difference.
If (and it is a big 'if') your amp has an extremely poorly designed power supply, and your mains is extremely noisy, then a proper LC mains filter placed close to the amp may make an improvement, but not a magic cable.
While there is a tendency on this website to dismiss expectation bias effects as 'it doesn't happen to me', given the lack of any scientific underpinning for mains cable claims, and the wealth of reports on the unreliability of human perception, my money would be that any difference you hear is not due to the cable.
I only buy when i hear a difference in sound.. I am very good exmaple of who do does not listen to what people say but what my ears tell me.. One thing people forget as well, you can never tell if you listening is the same as mine or any bodies for that matter. If you have tried this particular wireworld cables & cnt hear any change in sound... that sounds sad to me.. Cause its giving me much more listening pleasure.
