Steady on Revo, I've used Van Damme 75 ohm cable to make some digital interconnects 🙂van damme!! Do you enjoy throwing away your cash? Amazon basics cable is far cheaper & works the same.
The average hifi user doesn’t need to pay out for studio grade cable. Maybe @Gray was right- we’re a gullible lot 😉
But if we go by your initial argument, there’s cheaper cable that’ll do just as good a job, right? 😁Steady on Revo, I've used Van Damme 75 ohm cable to make some digital interconnects 🙂
'Studio Grade' from them means durable as much as anything else.
Their 'Tour Grade' mic and speaker cables will sound no better than cheaper stuff (though their Starquad mic cable demonstrably picks up less interference than standard two- core screened).
Can't remember what I paid for a few metres of Van Damme, but it wasn't expensive.But if we go by your initial argument, there’s cheaper cable that’ll do just as good a job, right? 😁
Please do not post money down drains, it might cause issues.Can't remember what I paid for a few metres of Van Damme, but it wasn't expensive.
Certainly there is cheaper - if you aren't going to physically stress them, then the freebies, to plenty of blind testers, are no worse audibly.
Many frown on their lapped, as opposed to braided screening - but there was the poster on here complaining of hum from his turntable.....which was cured by replacing his fancy, expensive cables with the old bootlace freebies.
Obviously no ground loops involved - he was connecting turntable to amp just using different cable. Whichever way you look at it, the 'inferior' bootlace cable had provably better screening from the hum than the more expensive stuff.
As for salesmen, I can honestly say that I have never bought anything on the recommendation of a salesmen - I don't like them. I've been told, more than once, that I could never be a salesman - something I take more as a compliment.
I'm not saying they're all bad - the law of averages says they can't be - but the ones I've seen, rely on a degree of gullibility from the customer.
To be clear, I don't blame people for gullibility - look at those multi-thousand pound fuses.
It's clearly stated, that they are the result of 22 years research into 'bottleneck distortion' that's got to be a good thing right?
Likewise, the benefits of really expensive cables are very persuasively and plausibly explained by people whose words can't be doubted - by the gullible.
Of course it's the choice of anyone to spend their money on whatever they fancy.
Just as it's my choice to post my money down the nearest drain if I wish.
Mmmmm they were 10 £ s Revo !!😊van damme!! Do you enjoy throwing away your cash? Amazon basics cable is far cheaper & works the same.
No one is gullible....but you've got an opinion that they cannot be gullible.
Most people here believe, strongly, that they are gullible.
You will never hear me ask you, or anyone else to keep their opinion to themselves - so please don't do that.
One more question for you.
Purchasers of £4000 or £8000 fuses....are they not gullible?
If not, why not....I would really like you to explain.
Yes, as you repeatedly say, it's all about choice. I agree.
But are they gullible?
The vast majority of people would surely agree with that.Can I just point out the obvious here the definition of "gullible"
"easily persuaded to believe something; credulous.
"an attempt to persuade a gullible public to spend their money"
Spending 50.000 on cables that make no scientific differences and carry provably the same information as a "good budget set" is indeed within that definition.
