Denon DL-301 ii and others
Entrigo
Recently sold my Audio Technica AT-VM95ML as it was just gathering dust, as the RigB AT-VM540ML and the AT33PTGII are getting all the play time.
But I now have a little itch for another cartridge and preferably something a little different from the Audio Technica - possibly something a little warmer, and I was thinking Hana SL, Denon 103 or Dymavector 20x2 (I know, very different beasts but was casting my net wide).
Then I came across the DL-301 II on a thread and the more I look around the better things I hear about it.
Has anyone heard it, even better compared to the AT33PTGII?
Or has compared any of the others against the AT33PTGII?
Will be used on a stock Technics arm with KAB fluid damper (headshell to be purchased according to cartridge).
Thanks for any input folks!
Warmer sounding try a Grado's Platinum 3 . Poor Man Koetsu
IMHO SL1200GR2 or SL1300G would be my next Step
Thanks for that. Aren't the Grado meant to be a bit "soft"? Seem to remember reading some people saying that - but I might be wrong. I am now starting to lean more towards the Dynavector, have read a few posts/reviews saying how good it is for "rocking out". But will look into the Grados
In terms of deck, I was hell bent on an upgrade to the higher tier Technics (1200GR2 or more likely 1300G) before realising they all have the same arm as the SL1500C... As mine is on a thick, wall mounted shelf, I thought the extra weight, isolation etc wouldn't be as useful as to someone who has it on a rack for example, and just the motor upgrade wasn't worth the outlay. So decided to splash out on cartridges and records instead.
At least for the time being... Next March is my 50th so a 1210G is likely on the cards!
Dynavector start @ £649 bit overkill for a £799 SL1500
SL1500 sound nothing like a well sorted 1300G/1200G these can compete with a £10,000+ turntable
Have a SL1300G/Grado & runs rings around my Rega Naid £13k which will be Sold
Grado sound " Soft " do not know what this means
Used various Grados myself for 40+ years
Best cartridge i ever heard was the Grado Epoch would buy one in a heartbeat. Only drawback they cost $12,000
Well, I had people saying the AT33PTG was overkill on it and it is anything but. (what does it even mean anyway??)
And after all, as mentioned the tonearm is the same as on the 1200GR2 and on the 1300G. Wow and flutter and rumble measurements are also the same. I am therefore still very unconvinced on the 1200GR2 or 1300G being a night and day improvement over the SL1500C...
That said, I haven't yet done an A/B demo - but very happy I haven't done one a couple of months ago or so, while in the throes of the upgrade bug. I suspect confirmation bias towards the SL1300G would have been sky high. Will probably do some in the next month or so, with a now much more objective and sceptical mindset, which is necessary to factually evaluate and compare two options.
And maybe it would makes sense to wait until I have done the comparison to to buy another cartridge.
I believe both the 1300 and 1200G use a higher grade arm. For a start, they have magnesium tubes instead of alu. Better bearings are likely used too and the arm housing looks different from underneath/open plinth. The improved drive is likely also a big thing and of course the whole platter/drive assembly has been substantially upgraded. Plinth is better built too.
Technics are clever, they obviously use incrementally better materials as models go up. Good thing is that even the cheap ones are benefitting from much of the technology and build quality at a fraction of the cost. Good enough for me (100C).
The one thing they all do have in common is the same spindly lever to raise and lower the tonearm. Seems Technics had plenty of those left in the parts bin 🙂
It will be interesting to find out what cartridge you end up with and why.
Well the 1200G definitely has a better arm and a magnesium one. However the 1300G has been reported by Technics head of something as being the same as the 1200GR2, which in turn is the same as the 1500C (and 100C). In terms of bearings, it did say somewhere that those used in the 1300G were the same as the 1200G but in the same interview, the chap said the whole tonearm was the same as the 1200GR2....
One thing Technics are is definitely cagey - it took me ages and extensive research and trawling through articles and fora to find this out.
The motor and drive will surely be better but again, wow, flutter and rumble measurements are the same as the 1500C (so as 100C I suspect).
Yes the plinth would make a difference but my deck is on a 3inch thick wall mounted shelf, so there's no risk of unwanted vibration there.
I'll likely get myself the 1210G next year as a 50th birthday present, but from all the research I have done, it seems the 1500C (and 100C) stack up extremely well to the higher level models..
In terms of cart, still not really sure i think the Dymavector 20x2 is edging it but no clear winner.
Anyway put in an offer for a new Sumiko Blue Point Evo iii on ebay and waiting to see if it's accepted.
The more I read about it, the more I think I am actually not going to find a better cartridge than the AT33PTGII for £600ish and any cartridge I find with a different presentation will also have trade offs I might not be entirely happy with...
As it mostly boils down to wanting some excitement and novelty, I might be better off just buying more records.
So if my offer for the Sumiko is declined, I might just stop searching for the cartridge and put the £6/700 towards the turntable upgrade next year - fully aware it will be very much a diminishing return purchase.
Reactions: nopiano
Put the £700 for a cartridge + sell your your SL1500
£1700 for a SL1200G ( total bargain )
Haha I had been watching that for ages. Only thing that stopped me buying it was the colour - I have an all-black system and not massively keen on the silver finish anyway.
That said, I had eventually decided to go for it last night, and of course it had just sold...
Same with the Sumiko cart - had been watching it for three weeks, day I decided to put an offer for it, it sold full price.
Cartridges are very personal things. That said we have similar TTs so here's my two pence.
I've previously had a Hana SL - this plays lovely together with a Technics TT. I have a SL1210GR (and will also myself up this to a G at some point in future). Mine too has a KAB damper and my phonostage is a BigBottle 3 valve phonostage running Telefunken valves. I'm not sure what phonostage you've got, but I struggle to see what I could buy that would better this and you can pick up a good used one for circa £800 which might be a future thought for you perhaps.
That said, the reason for my post is my current cart is a Hana ML. I took my deck and SL to a bake off not long after I'd got the SL and someone had a ML so I got to hear them back to back on my deck. The jump was substantial. I ended up selling my SL buying and ML.
With hindsight I should have saved more pennies and gone straight for the ML in the first instance.
Anyway, not sure if that's any use in any way. But just my two pence.
Reactions: Entrigo and nopiano
Yeah I bet. I did look at the ML just slightly out of budget, especially as saving for the 1200G - still not convinced it will be a night/day improvement and 4x better than my current TT but happy to be proven wrong once I start demoing - but yes it does sound good.
Who knows, if I find a used 1200G, might treat myself to the ML as well!
Nothing four times the price will give you four times the performance in hifi. It's all diminishing returns 🙂
Hahah yeah. I am quite aware of that, and that at least 50% of the purchase would be just to get a nicer looking and feeling deck.
But still it should be a clear step up sonically to justify the cost. I'll be looking to set up the demo so that one could quickly switch tables (and possibly bring a friend along to do that, so I would be auditioning blind.
I’ve just read a glowing review of the new Ortofon MC, the X series. Unusually, it has very good tracking, sometimes a weakness in MCs. It was the top model for about £875 in Hifi News. Hifi Choice have reviewed the entry model, which I think is more like £275 which is remarkably reasonable.
