Question help adjusting turntable
iroh
13
alright, so basically i have my turntable now, a technics sl b2 with a at95e with at headshell
it plays well im quite surprised at the quality but i was wondering what adjustment i should do, if any on the anti skating and weight thing (assuming the whole head is placed properly xD)
so yeah let me know if there's something i should look out for to optimize my listening/protecting my vinyls!
Gray
If you haven't already, start by getting yourself a cartridge alignment protractor and a way of accurately setting the stylus downforce (tracking weight).
This can either be a balance or electronic scales.
Mine aren't current so I'll leave others to recommend things.
And you can knock the 's' off of the plural for vinyl :giggle:
iMark
451
232
19,270
The classic way to do this are a few steps. Have a look at the turntable's manual.
First balance the tonearm. This means that with weight set to 0 the stylus should float freely at the same height as the the platter. Adjustments can usually be made by moving the counterweight forwards or backwards.
Next thing is to set the weight at the level suggested by the company that made the cartridge. Our Ortofon 2M Blue is set to the recommended setting of 1.8g.
The last thing to do is set anti-skating. This differs from manufacturer to manufacturer. Our Pro-Ject turntable simply has a little weight on a string. Other turntables have different solutions.
ASK THE COMMUNITY
