B
		BIGBERNARDBRESSLAW
Oldboy said:The Sky issue sounds like an issue with the Sky box to me, either the box isn't sending the audio correctly to the amp or there is some sort of conflict between the two units. How is the audio sent to the amp, via optical or HDMI? I know there have been some issues with Sky boxes and the way they deal with sound but I thought they were all resolved, have you contacted Sky for advice? If it was the 2020 at fault here I would expect the issue to continue across all sources, of course the usual things should be tried like changing connections and leads etc but I'm sure you have tried all that eh.
Not 100% sure whether this problem is now sorted, as it's a very intermittent problem (I could go days without hearing a problem), but I've changed the audio output from Sky from HDMI to optical, and I've not heard anything since. 😛ray:
Thanks for all your help Oldboy. :cheers:
 Facebook
Facebook Instagram
Instagram
