Amp for Wharfedale Diamond 12.3i Speakers
FLSTN
Hello,
I own the Fluance RT85 turntable and the Diamond 12.3i speakers and have narrowed my amp search down to the following three products:
  1. Arcam A5+
  2. Marantz PM6007
  3. Yamaha A-S501
I am unable to find a location to hear these amplifiers, so I plan to purchase two of the above amplifiers, then decide which one would work best based on hearing them.
The room size is medium and I do not crank the volume up too high. My budget is about $1100 for the amplifier.
  1. Which two of the above amplifiers would provide the best phono stage?
  2. Which two of the above amplifiers would provide best overall sound match for these speakers?
Appreciate the feedback.
Hello,
  1. Arcam A5+
  2. Marantz PM6007
  3. Yamaha A-S501
Hi, I recommend to include also Rega Brio either Mk6 (previous version) or new Brio Mk7 which include also very good Dac inside. Sonicaly mk7 is not so much better thanMk6, except Dac. All amps selected by you are very good, Yamaha is a looker. Arcam A5+ most potent and authoritative sound from the group. Marantz PM6007 is very musical but somehow sounding "nice and creamy", masking some details. Not so much fot audiophile type of listener. Rega has lot more energy, rythm and pace. And truly amazing phono MM preamp is inside Brio, by far best of all amps here in selection. All those amps will sound very good with your Diamond 12.3 speakers. They are easy to drive a not over detailed in treble. BR.
Reactions: FLSTN
Hello,
  1. Arcam A5+
  2. Marantz PM6007
  3. Yamaha A-S501
Welcome to the forum,
Unfortunately, if the Turntable is your only concern I would say neither.
Look at a pure amplifier that has money spent on a decent phono stage and doesn't have Bluetooth or digital inputs if they are not required.
Reactions: FLSTN and pd44
Hello,
  1. Arcam A5+
  2. Marantz PM6007
  3. Yamaha A-S501
Welcome to the Forum, FLSTN!
You've done your homework, and I like your options: I'd order and trial the Yamaha and Arcam units, to answer your first question. You can judge for yourself which one's capabilities and features please best with and for your favorite recordings. I think "speaker-matching" is over-reported and claimed: trust your own tastes and preferences, and you are approaching your quest the best way.
Yamaha is an excellent music company, and they produced an excellent set of "separates" I used and passed on many years ago -though I've liked Rotel and Cyrus for many years now since.
Enjoy your trial and your eventual selection!
EDIT: Here's a good review on the Yamaha: https://audioappraisal.com/yamaha-s501-review/
Hello,
  1. Arcam A5+
  2. Marantz PM6007
  3. Yamaha A-S501
From your mentioned options, I´d pick the Yamaha.
Solid, no nonsense amplifier, exceed specs in terms of power.
But, if your $1100 budget is just for the amplifier, I´d see
The $1,100 is my ceiling. I’m fine keeping under it.
My choice from your presented options would be the Yamaha.
Solid nonsense amp that exceeds specs in terms of power.
But maybe try find one of the higher-end Yamahas A-S series 2nd hand, like the A-S1000 or 1100, if you don´t object to buying used.
The sound will will not be much better (if at all) but the build quality will and I believe the phono amp is of higher quality, what I think would be important to you given your source.
Thank you for all the replies and recommendations. After reading about the Yamaha amplifiers I am going to move forward with either the A-S501 or the A-S701.
The only negative on the Yamaha amplifiers that I’ve seen on-line is the phone stage can be a bit lacking, so I plan on buying a pre-amp as well. I am looking at the Cambridge Audio Alva Solo or Duo as a viable pre-amp.
Reactions: GroeneLeeuw
Yamaha's phono stages are poor, and I say this from first-hand experience. Otherwise, their amplifiers are very good.
The Rega Brio is a good shout, but so is the Arcam A5+ (which has an excellent phono stage) if you like a warmer sound. The Audiolab 6000A Mk2 is a more balanced and flexible amp than either, with the ability to drive a wide range of speakers comfortably, and that also has a very good phono stage. For less money, the Mission 778X offers many similar qualities, but isn't quite as neutral sounding (I have both here, and have done direct comparisons with a range of speakers).
Mission 778x asr don't like (sometimes an audiolab 6000a mk 1 can be had for around 500 euros)
Reactions: FLSTN
Thank you for the recommendations. I ended up purchasing the Yamaha A-S701 (yes, the phono stage is not very good) and the ART DJ Pre II pre-amp. The amplifier is absolutely amazing! Really works well with the 12.3i speakers. The pre-amp sounds great as well and works well with the Ortofon 2M Blue stylus. Very happy with the system.
Enjoy!
Not really an issue for FLSTN now he has purchased the (excellent) A-S701, but I really don't give a lot of credence to ASR, and I think 'don't like' is putting it a bit strong anyway. I'd say it comes out as pretty average in that test.
Congratulations. The A-S701 is a fine amp, and it's built to last as well. You can always upgrade the phono stage in time, and you've got a great cartridge in the 2M Blue. Now focus on the music and enjoy!
About the Mission review at ASR, it basically says: it´s not state of the art but fine for most if not all listeners, you will not hear anything weird or strange. Use it within spec with suitable speakers and everything´s fine.
Exactly. The Audiolab 6000A MkII is certainly the more balanced amp, and has more to give with more demanding speakers, which is one of the reasons I won't let it go.
