Yeah yeah OK, a Technics 1200 is considered a DJ deck. I looked into replacing my Sony DD DJ decks with a hifi deck. Anything within budget, just didn't seem very sturdy. Many, wouldn't even allow me to easily change speed. So I plumped for the Technics. I knew what I was getting. It's well made. My Sony, which was pretty similar, always sounded good enough to me. I use my Technics with a nearly half kilo record weight/clamp and a perspex mat but no major upgrades.
I've got a couple of old headshells. One is generic, the other is Stanton. I've never really thought about them too much before now. I've used an ortofon concorde type dj cart before now. I'd had my eye on the Ortofon 2m range for a while. Thought the one with built in headshell seemed like a neat idea.
I recently bought a Nagaoka MP 110 with headshell. Then I decided to buy a Technics headshell, so my deck would be complete. Which should I use? Or will it make no difference? Is it better to use the cartridge manufacturers headshell, or the stock headshell, from the turntable manufacturer?
