MajorFubar
- Mar 3, 2010
- 690
- 12
- 0
MajorFubar said:wow it worked...wasn't sure if this place 'did' animated GIFs....
MajorFubar said:I've never found anything on youtube to moisten to, I thought all that kind of stuff was banned from YouTube 😛
ellisdj said:To RadioFrog
"because of my beliefs I hadn't listened to the video" - why would you not watch a video because of a preconception? Its a hifi video, its a video on your hobby
That a bit stubborn you must admit - but fair play for admitting it. Probably nothing Gained but certainly nothing lost
Thompsonuxb said:I waited a good part of the evening waiting for such a response....
Just bare with me a moment while I put on my internet kung fu fighting pants.....hmmm, they feel tight.
This being an area that's not had much cover on this site.
So Steve_1979, you're not familiar with the difference between modulated D/C (what you'll get from your amp and causes the speaker to move) and an A/C electrical signal? - Usually seen coming in off your mains supply.
It's easy to confuse the two but different they are.
The PCB's in your amps innards are fed D/C hence the use of capacitors.what's amplified and outputted is not A/C.
I'm actually going to sit and wait for you fake boffins to go read up on this and see what you come back with.
Andersοn said:Guyz!!
What we really need to get down to is MAGNETS, how do they work? You can't explain that!
#steve_1979 said:ellisdj said:To RadioFrog
I haven't watched the video because it's meaningless. The sound may well change on the film but there are several possible factors which could be the cause of any change in sound which makes the whole exercise pointless.
ellisdj said:#steve_1979 said:ellisdj said:To RadioFrog
This is a demo at the industries biggest event infront of the industies top players by a major manufacturer what do you think they would do? Honestly its just plain silly to have that atttude , You wont watch it out of spite - its up to you.
abacus said:2. Use Audiodiffmaker to see if there is a difference
ellisdj said:There is no reference in the whole video to any specific cable in any way. It's not about cables
The reason the sound changes is because it changes the video is filmed by a German guy who is not related either.
These types of videos will get more and more frequent it's inevitable and it's great because I couldn't go to the Munich high end show but still get a sneak peak of what was there.
Even the cut video at the end you can hear the difference between the niagra and no niagra in use. It's a video about that product and just highlights a few things on the way.
Don't worry if it's below you - that's how your comments read
matt49 said:abacus said:2. Use Audiodiffmaker to see if there is a difference
Recently I suggested this in a similar context over on the PFM audio forum. According to one of the bods over there, the time alignment in Audiodiffmaker doesn't work, so the whole tool is next to useless. (BTW this guy is an experienced electronic engineer and an "objectivist", and it's certainly not in his interests to diss Audiodiffmaker.)
steve_1979 said:ellisdj said:There is no reference in the whole video to any specific cable in any way. It's not about cables
OK I've just watched a few little bits of it and as expected it's just some guy waffling on about your usual audiophool pseudoscience rubbish.
As for the trumpet bit they both sound the same on my tablet. I didn't bother using my headphones because as I said before, even if I do hear a difference it would be meaningless as there are several different factors which could be causing the difference.
BigH said:matt49 said:abacus said:2. Use Audiodiffmaker to see if there is a difference
If that is the case why often is there no sound then?
matt49 said:BigH said:matt49 said:abacus said:2. Use Audiodiffmaker to see if there is a difference
Do you mean why is no sound audible, or why is there no sound? If the latter, I'm not confident the premise is correct. In either case, I can't answer the question, I'm afraid.
ellisdj said:Your stubbornness being the main one. I said I have been listening on a good sound card and average headphones and a phone or tablet speaker is not good enough to test it
Just because he is not using avi actives you don't give him the time of day - again up to you.
