audition
gillieboy67
9
have drawn up a shortlist of possible components for my new hifi
michell gyro se with technoarm a
lavardin is reference amp
electrocompaniet ec1-3 amp
sonus faber venere 3.0 speakers
magneplanar mg 12 speakers
would welcome comments and opinions,also anyone in the edinburgh area who knows of stockists of any of the above so i could audition them,thanks
jonomd
27
Loud and Clear in Edinburgh may be a possibility. Been to the one in Glasgow which were very helpful ..
Lavardin, Sonus Faber and Magneplanar are listed in their core brands. Also have good choice off higher end turntables and amps.
DocG
54
If your budget allows the Venere 3.0, I wouldn't bother about the MG12. The Magnepan 1.7 is a massive step-up over the MG12. You've lined up some excellent amplifiers (expand the list with Cno's suggestions!), which should all be capable of driving these speakers!
Just my experience... Do try them all with your own ears!
gillieboy67
9
thanks guys will check out your suggestions,would appreciate any advice/experience as to what would be a good phono stage,cartridge,speaker cable,this will be my first mid/high end system so all help is greatly appreciated :cheers:
stevebrock
183
With regards to the Gyrodec (my next purchase, at somne point) do you intend to further upgrade the arm at a later date? Say, to a SME IV ?
Heard the Gyrodec with both arms - with the SME IV it is phenomanal - I will be sticking an RB303 on mine iniially with the intention of an SME IV - as I want to go this route I don't see any need for the Tecnoarm as as it is. Cart would be someting like Benz Micro Ace
Let us know how you get on and what cart you put on - its beautifully engineered deck.
gillieboy67
9
yes,although i may go for the sme iv with the turntable,have to say am also tempted by the nottingham analogue hyperspace tt,any recomendations for phono stages?
