Have my heart set on RS3, heard some last week but I need to listen to the Dyns & KEFs just to make sure the RS3 are for me!
Budget up to £700-800
I live in Lincoln, UK
richutd18 said:Hi,
I had the RS3's in Gloss White, their great speakers, in particular for positioning. I now have the X12's in Gloss white, for me their best speakers I've owned. In our lounge I have them around 20 to 25cm from the rear wall and they sound amazing, Never heard the Kef's but had them in my short list and the DM2/6.
if you can accommodate them I would recommend them highly.
richutd18 said:Hi,
stevebrock said:Have my heart set on RS3, heard some last week but I need to listen to the Dyns & KEFs just to make sure the RS3 are for me!
stevebrock said:I have recently moved!
The RS3 may also work in some rooms, where the Neats cant - no hard & fast rules about speakers/room acoustics
BigH said:I had a lot of trouble tracking down the Dyn X12 and then the dealer did not have KEFs. There is a dealer in Essex that has Dyns but not the X12 I suggest you check they have them in stock before going. Check on the Dyn website for dealers. I tried the X12s with Marantz Pearl Lites and did not like them the treble was too forward for me. Try the KEF LS50s but maybe the Rega amp is not enough to drive them. I think most will be a step-up from the RS1s which were probably the worst speakers I auditioned.
