Riksta73 said:Is wired networking and digital input worth £250 as you can get the AS500 for £199?
Timot said:Just got this amp one month ago. I use it only with airplay. One problem I have though is that sometimes no sound is comming out of my speakers (amp is displaying the music on screen)... Although I shut it down and on again and have the latest firmwire it just won't work. And the day after it's working again... Is there any solution to this ?
Zappa Doc said:Timot said:Just got this amp one month ago. I use it only with airplay. One problem I have though is that sometimes no sound is comming out of my speakers (amp is displaying the music on screen)... Although I shut it down and on again and have the latest firmwire it just won't work. And the day after it's working again... Is there any solution to this ?
big issue here with my r-n500. almost the same symptome i.e. no sound on speakers but in almost all input mode, NET (including net-radio and server), Optical, USB, only tuner and CD continue to work... if I enter the Advanced Setup and Init ALL (reset the amp) everything work as expected until the firmware bug again... very frustrating as it's a new amp (bought 2 days ago) and when it works the sound is amazing... I do not know what to do...
For example:
- I have an onkyo CD player so I connected it to the CD input and it works, then I connected it to the Optical 1 input as it provides an Optical out but this time no sound... 🙁
if I check the signal (option > signal info) I get PCM/44.1/2 ch. so the signal is recognized but no sound until I reset the amp or power off/on several times...
- the same, using the NET Radio or my Audio server (DLNA), everything work as expected until the bug occurs... intit/ALL reset the amp and then this works again...
This is really weird...cause after googleling the issue, I didn't find any entry, no one seems to have this problem... is there a way to contact the yamaha assistance...
davedotco said:Zappa Doc said:Timot said:Just got this amp one month ago. I use it only with airplay. One problem I have though is that sometimes no sound is comming out of my speakers (amp is displaying the music on screen)... Although I shut it down and on again and have the latest firmwire it just won't work. And the day after it's working again... Is there any solution to this ?
For example:
If the amp is brand new and faulty, be it hardware, firmware or software, take it back and ask for one that works.
You should not have to put up with this if your diagnoses is correct.
