Blind testing to be viewed as credible by those that want it needs to meet alot of strict criteria. It is way too much time and trouble to do regularly. To prove or disprove a point I can see the sense, but for everyday product evaluation too much trouble.
For example with cd players I have read of.
The equipment must not be faulty, it must be tested to make sure it meets the redbook spec, so you are not identifying it due to it distorting the sound. So you are taking measurements with test equipment anyway.
The output voltage must be the same, the spec is 2.5v. Players range from 2-3v with some higher than 3v which technically means they have a design fault as they fail to meet the redbook cd specification. A higher voltage will lead to a higher volume, at low levels this would not sound like an increase in volume but an increase in clarity. If too high a voltage for the amplifier used, it could cause distortion, this would not be readily distinguishable as distortion, with my Sony dvd player it made it sound more dynamic, crisp, detailed particularly in the bass, but made vocals slightly less natural and music occasionally wearing, the sound was not as smooth as it should have been.
Level matching to less than 1/10th of a dB when you can only easily distinguish 1dB difference as an increase in volume. The 1/10th of a dB will make it sound different.
Time matching players which unless you are listening to a test tone or pink noise can mean opening up the cd player, as they have to be time matched to the point no subconcious timing clues remain to enable you to pick out which player is which.
Double blind with controls so no clues from those organizing the test, due to the skeptics this means having independent observers or no one will believe the results are not due to poor test controls.
Alot of testers and repeat tests to make the results statistically relevent rather than just dumb luck.
For stereo there is a sweetspot for listening and with lots of listeners not everyone maybe in that spot, the people will also effect sound quality by their presense, acting as sound absorbers of high and mid tones and objects in the room causing sound reflections making the listening environment less ideal and sound quality harder to distinguish.
Audio short term memory for easy comparison, is very short so you are listening to a succession of short identical clips. Lots of different frequencies and harmonics would need to be tried. It would be tiring and if people believe they have golden ears and are trying to be critical listeners this could be very frustrating.
This is probably just the tip of the iceberg. In short it is alot of time and trouble to do right, and if you do it wrong no one believes your results.
You also have to ask why bother, audio fidelity can I believe be measured with equipment, so what is the point in blind listening tests (except in arguements over what is and is not audible to humans). I want to know if the cd player distorts the sound and if its output voltage is correct, if the amplifier distorts sound, how it handles clipping and if its quoted power rattings are accurate. What the speakers frequency range is, how flat their response, if they introduce any distortions, what their ideal placement would be, what their impediance is like across their frequency range. There are lots more things that can be measured and have a known effect on sound quality. You just have to educate the reader.
I would argue more for informative articles, educating the readers to enable them to understand what makes one thing sound better than another rather than just someones opinion from blind or sighted testing saying it does. I would like to see measurements using test equipment and protocols of competing products so they can be objectively compared. This would inspire me to trust the experts who are advising me know what they are talking about and measurments would help to illustrate and validate their subjective opinions more than flowery words.
For example the following site tests dvd players using measurement and seeks to educate it readers, I find it more usefull than a subjective opinion on what dvd players looks best.
http://www.hometheaterhifi.com/volu...uide-to-progressive-scan-shootout-1-2003.html
EDITED BY MODS for house rules violation
