steve_1979
manicm said:steve_1979 said:manicm said:Profanity on a forum like this is never funny - it's banal and inane.
EDITED
Indeed
:cheers:
EDITED
Indeed
professorhat said:Clicky
Randi is to cable threads what Hitler is to fourms in general.
(for the lawyers - purely in terms of, eventually, given enough time, Randi will be mentioned in a cable thread. I make no other associations between Randi and Hitler 🙂 )
TrevC said:manicm said:Overdose said:I think you are confusing the amount of data that can fit on a CD to its dynamic range.
One of the reasons they limited the resolution to 16/44 was because of capacity. If they could have gone higher they almost certainly would have.
I very recently bought Bee Gees The Record compilation, and both CDs are packed with over 78 minutes of audio. My CD player was definitely noiser than usual. This had to be down to the longer length. Also, Too Much Heaven, while not harsh, was not sounding as smooth as I expected. I'm not saying this is absolutely because of the longer length, but I'm suspecting so.
The CD medium was in no way perfect.
The length of a CD has no effect on sound quality.
manicm said:TrevC said:manicm said:Overdose said:I think you are confusing the amount of data that can fit on a CD to its dynamic range.
I did not say that absolutely, what I did say is that an extreme CD length may place additional strain on the laser and thus may affect playback. Is that so far-fetched?
manicm said:the record spot said:manicm said:One of the reasons they limited the resolution to 16/44 was because of capacity. If they could have gone higher they almost certainly would have.
With respect, this is a nonsense. I have several CDs that go beyond 75 minutes, none of which results in this issue on playback. None.
No, this is not nonsense, it is my experience - both discs run over 78 minutes and my CDP was noisier than usual - are you saying I'm imagining that? It may not hold true on your player but it is on mine.
manicm said:Anderson - why do you insist on putting words in my mouth?? Where did I ever mention compression? Do you agree that a CD player is a mechanical device? Its transport consists of a motor and laser. And depending on the condition of a disc, those lasers are not infallible.
My ultimate point is that, since CD was developed in the late 70s, and launched around 1982, the 16/44 format was not chosen because it was deemed the absolute best, it was dictated by the technology limitations of the day. And that is the pure and simple fact - I'm not debating whether it's good enough or not - that's been argued to death.
the record spot said:The conclusion that your player is experiencing noise thanks to a CD whose running time is longer than 78 minutes doesn't bear out across the board. Why would a CD player's laser malfunction in its reading ability? If my players have never done it, and there's been a few, surely it's less to do with the "problem" you're attaching to CD when it's more likely a flaw in your player?
Why be concerned? It was perfectly well written in a language I know well; it is perfectly understandable. Did I agree with it all? I would say I'm closer to no than probablly not. The bit that interested me was the bit about the Swedish BC. The bit that not a single person here, or in the comments below the article, has mentioned.Covenanter said:ifor said:I expect many have read this before, but it's new to me.
http://www.avguide.com/forums/blind-listening-tests-are-flawed-editorial?page=1
I'm open minded when it comes to the interconnect and speaker cable debates. I've never bothered, yet, to make comparisons, either blind or otherwise, but I do get exceedingly irritated by fundamentalist non-believers. What won't they just relax back to a position of extreme scepticism? 🙂
I do believe that double blind ABX is probably flawed, but that doesn't make me a believer. Curiosity got me googling and I ended up at the page for which I've given the link.
I'm deeply concerned that you might think that the article makes any sense.
Chris
manicm said:the record spot said:The conclusion that your player is experiencing noise thanks to a CD whose running time is longer than 78 minutes doesn't bear out across the board. Why would a CD player's laser malfunction in its reading ability? If my players have never done it, and there's been a few, surely it's less to do with the "problem" you're attaching to CD when it's more likely a flaw in your player?
I too have had about 4 disc players. I'm not bluntly blaming the CD or my player for what I'm experiencing - and it's not that loud or malfunctioning - but I repeat it's my experience.
Also, I have Roger Waters' Amused To Death which is around 76 minutes long and it doesn't happen. My point is that a CDP is very much a mechanical device, and perhaps some are less tolerant than others, as the motor/laser combinations are sourced from different manufacturers.
Another example is my Pioneer DVD player - which was very sensitive to mildly scratched DVDs, which my subsequent Blu-ray players would play with ease.
Do you remember DualDiscs? When they were released many hifi companies warned customers about them, because many CD mechanisms from different makers were built to withstand specific tolerances, and these discs may have exceed those tolerances.
I will repeat my statement that the CD, and indeed perhaps any mechanical mediums are far from perfect.
ifor said:The bit that interested me was the bit about the Swedish BC. The bit that not a single person here, or in the comments below the article, has mentioned.
davedotco said:In recent years codec designers have reduced these effects and such a 'trick' is now much harder to pull off.
manicm said:davedotco said:Some years ago I met a chap who could not only pick compressed audio from uncompressed audio but could identify the codecs being used in each case.
He did this by training himself to listen for certain 'tells', compression effects created by the different codecs, he wasn't listening to the music at all.
And did he tell by blind testing?
manicm said:davedotco said:In recent years codec designers have reduced these effects and such a 'trick' is now much harder to pull off.
Yet somehow I preferred earlier versions of the Lame MP3 encoder.
davedotco said:I still cannot tell the difference between Ogg Vorbis (at 320 kbit/sec), downloaded from Spotify and FLAC files of the same disc, both from my hard drive. Maybe a better system....... :?
matt49 said:davedotco said:I still cannot tell the difference between Ogg Vorbis (at 320 kbit/sec), downloaded from Spotify and FLAC files of the same disc, both from my hard drive. Maybe a better system....... :?
In my limited experience (an hour or two of comparison using Foobar ABX earlier this week) it is indeed very difficult. I lined up some files ripped to both ALAC and Ogg Vorbis 320kbps. I did two ABX runs of 10 passes each. On both runs I got the ABX right 100% on the first 5 passes. But after that I just fell to pieces and ended up with 7 out of 10. I don't know if it was listening fatigue or cognitive confusion or just that I'd got lucky on the first five passes. But I suspect that your friend's "party trick" could be done with Ogg Vorbis at 320 kbps, assuming you picked the right music and spent a lot of time practising.
The system was PC via USB > modded MDAC > Hifiman HE500s.
I'll give it another go when I have the time and energy.
TrevC said:manicm said:the record spot said:manicm said:One of the reasons they limited the resolution to 16/44 was because of capacity. If they could have gone higher they almost certainly would have.
It could be the CD itself, check for fingerprints on the outer part of it. The longer a CD is, the closer it plays to the edge.
TrevC said:manicm said:TrevC said:manicm said:Overdose said:I think you are confusing the amount of data that can fit on a CD to its dynamic range.
Yes, that is nonsense.
