malthus80:matthewpiano:malthus80:
matthewpiano:Would be worth trying the Rega Saturn as well.
Have heard a saturn, no where near enough of an upgrade over the marantz but thanks for your suggestions.
Fair enough. I reckon the best thing would be to book a good long demo and to try a couple of different CD players, a couple of different amps, and some alternative speakers. Mix, match, swap and change to see which takes you closest to the sort of changes you want to make. Then book a second demo where you can focus on trying a shortlist for that system component.
I was thinking of the planet not the saturn. I reckon thats good advice above. I have received many good suggestions so need to draw up a shortlist. Many thanks
+1 on the Saturn, man. It's amazing what this cdp can do. I think that Rega hit a homerun on this one -- build quality is superb, the design (in traditional Rega top-loading fashion) is quirky enough to distinguish it from your mother-in-law's Tesco, and the sound is simply amazing. The Apollo probably remains one of the better players around, but the Saturn tops even that with greater depth, detail and pace. I play anything from Hot Chip to Miles Davis to Nigel Kennedy on it in my bedroom system and it certainly does not disappoint.
I have honestly only heard one cdp that possibly betters what it can do, and that's an Isis on a system with Dynaudio Evidence Temptations and VTL pre-power juicing it up. Not apples to apples by any stretch, as far as equipment cost and dimensions are concerned.
Simply put, if you're still relatively mindful of cost and yet are willing to spend slightly more than the average joe, you won't go wrong with a Saturn.
