Infiniteloop
ellisdj said:Interesting you got an uptone audio regen - what do you think of it - what USB cable do you use with it??
What are you powering the Regen with?
I could tell you a 100 things to do to give you better sound like that has done, are you on AVF?
I almost daren't tell you that it has made a difference after the last time I raised this on here....
Anyway, to hell with it. To my ears it seems to make the sound more defined. Leading edges are sharper and bass is more textured and, well, yes, more defined.
It's being powered by the PS it came with and the USB cable is a simple printer cable, because I prefer the sound of that to almost any other USB cable I've used into the Devialet 200. When I use it with my Chord DAC, I prefer a fairly basic Chord Cable USB cable to the printer cable (the Chord cable seems a bit laid back, which seems to suit the Chord DAC). In both instances, the sound is better. It is subtle, but I can tell when it isn't plugged in.
I'm not on AVF. - Whatever that is....
 Facebook
Facebook Instagram
Instagram
