Richard Allen said:davedotco said:Richard Allen said::clap: +1.
And I have spent many an unhappy hour "tweaking" just as you say. One of the reasons I don't do live work anymore. At least in the studio you have some form of constant whereas live venues can be tedious due to the re-EQ from the ground up due to the venue itself.
Well said Cheeseboy.
Nah, live sound mixing is way more fun.
Soundcheck is usually a waste of time in terms of balance and eq, the audience change the acoustics out of all proportion and the musicians invariable play and perform differently in front of a live audience.
Can be real 'seat of the pants' stuff, beats recording every time.
As an aside, I think I should have been born 20 years earlier, recording jazz and other popular music live to that new fangled two channel 'stereo' would have been brilliant.
So come on Dave. Thinking cap on n all that eywhat??.
Back to the thread. Tone controls. I think that a traditional baxandall tone stack would be unnecessarily intrusive on the signal path but what about a properly designed 4 band parametric?? Works in the pro domain on channel sections. :?
I was never a big fan of parametrics, for live (touring) work it is overcomplex and so easy to mess up. My Midas console had a simple 4 way eq, with two sweepable but constant Q mids. Decent high pass filtering too, which I found invaluable.
For home use, I want eq to do two things, firstly to address overall tonal balance, I found the 'Tilt' switch found on some Quad pre-amps to be entirely adequate. I lived with one for a while and used it flat or slight downtilt for classical and talk (radio) and with a slight uptilt on pop and rock. Mid '80s Quad ESLs in a decent sized room, very livable.
Secondly some decent eq at the bass end, primarily to help with room positioning, shelving below about 300hz and decent high pass filtering would be fine. Using a parametric to 'notch out' peaks an fill dips usually causes more trouble than it is worth.
I was never a great fan of the Baxandall circuit, far too much effect in the midband for my taste. I recall a circuit that, applied boost/cut to the frequency extremes at modest settings with the effect spreading more to the midband at more extreme settings, seemed like a good idea but I can not remember details or name, if it had one....... :?
