Searching for an AV rack...
DjP
19
I've been doing a lot of web searching, but can't find the right piece of equipment. I know what I want, just can't see it, but I figured someone on this forum might...
I need an AV rack for 40" LCD, QAV speaker kit plus receiver, Sky HD and Pana BD30. The top shelf load will be 70kg. This is the spec I think I need:
* clear glass
* 3 or 4 shelves
* top shelf 10mm glass
* 100-110 cm wide, height and depth not so important
* D-shape or corner stand (ie not rectangular, ideally D shape - with the back corners lopped off)
* budget is £300 ideally. Possible to spend more, but I'd rather not.
Anyone any suggestions?
Thanks,
DjP
not sure as to quality, but I was looking for one a while back (and then ended up not buying one for reasons I cannot recall, but make involve the words "you're not spending any more bl**dy money on that av hi-fi thing") and trawled through amazon for a good idea as to what's out there. Search for Alphason.
