Since adding a Cyrus X Power to drive my front CM8s, what should I do with the MCACC settings on my LX53 amp? ( I have a 6.1 setup of CM8s and CM1s plus two small front heights). I'm particularly concerned that the MCACC might adversely limit the front L/R CM8s, affecting their stereo and SACD/DVD-A music performance.
Specifically, the MCACC gives you a choice of SYMMETRY ("symmetric correction for each pair of left and right speakers to flatten the frequency-amplitude characteristics), ALL CHANNEL ADJUST ("a flat setting where all the speakers are set individually so no special weighting is given to any one channel") and FRONT ALIGN ("sets all speakers in accordance with the front speaker settings (no Eq is applied to the front left and right channels).
Should I programme different MCACC settings (six memories are available) for stereo, SACD and/or movie use? And which of these above should I use. (the manual leaves you at the crossroads at this point). Any ideas?
