Hello all,
I need your help and support.
I have the two following systems::
(A)
Harman Kardon Receiver AV330
https://www.cnet.com/reviews/harman-kardon-avr-330-review/
Characteristics
DISPLAY
Tall speakers B&W XT4
https://kahlaudio.com/products/bw-xt4-tower-speakers-lots-of-positive-reviews
https://hifi.nl/nieuws/37146/B-W-XT-serie-geintroduceerd.html
(B)
A quite rare JVC TH-L1B
https://www.crutchfield.com/S-gJRpp1jvGku/p_257THL1/JVC-TH-L1.html
View: https://www.youtube.com/watch?v=8rs3OY69b0U
Characteristics
- Keep the two separate, enjoy movies with the JVC and music with the HK and the B&W?
- Connect all speakers to the Harman Kardon, using the tall B&W left and right speakers instead of the L&R of the JVC?
- Connect all speakers to the JVC home theater system, using the tall B&W left and right speakers instead of the L&R of the JVC?
Bear with me for the basic question as I am not an expert.
Thank you for your support.
(A)
Characteristics
DISPLAY
- Display Dimmer
Yes
- Amplifier Output Details
55 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.07% - 2 channels (front)
55 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.07% - 1 channels (center)
55 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.07% - 2 channels (surround)
55 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.07% - 2 channels (surround back)
65 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.07% - 2 channels (main) - Response Bandwidth
10 - 130000 Hz - Signal-To-Noise Ratio
100 dB
- Digital player type
none
- Type
AV receiver - Subcategory
AV components - Functions
AV receiver - Sound Output Mode
Surround Sound - Built-in Decoders
DTS Neo:6, DTS decoder, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, DTS-ES decoder, Dolby 3 Stereo, Dolby Digital, Dolby Digital Surround EX, Dolby Pro Logic, Dolby Pro Logic II - Surround Sound Effects
VMAx virtual surround sound - Surround System Class
5.1 channel - Digital Sound Processor (DSP)
Yes - DSP Presets
5ch stereo, 7ch stereo, Enhanced, Hall, Movie, Music, Theater, VMAx - Additional Features
EzSet, Midnight Mode, balance control, multi-room audio output, on-screen display - Bass Control
Yes - Treble Control
Yes - Built-in Clock
sleep timer
- Nominal Voltage
AC 120 V - Frequency Required
60 Hz - Power Consumption Operational
890 Watt - Power Outlets
2 AC outlets - Type
power supply
- Brand
harman/kardon - Product Line
harman/kardon AVR - Model
330 - Packaged Quantity
- Type
fluorescent
- Tuner Type
Radio tuner - AM/FM - digital - Signal-To-Noise Ratio
70 dB - Total Harmonic Distortion
mono: 0.2%, stereo: 0.3%
- Timer
sleep
- Output Power / Total
385 Watt - Input Impedance
47 KOhm - Input Sensitivity
200 mV
- Output Power / Channel
55 Watt, 65 Watt - Output Impedance / Channel
8 Ohm - Frequency Response
20 - 20000 Hz - Total Harmonic Distortion (THD)
0.07 % - Channel Type
center, front, main, surround, surround back - Channel Qty
1, 2
- Tuner Type
digital - Tuner Bands
AM/FM - Tuner Frequency Range
AM: 520 - 1720 kHz, FM: 87.5 - 108 MHz - Tuning Display
fluorescent display - Preset Station Qty
30 - Antenna Form Factor
loop AM / wire FM
- Headphone Jack
Yes - Coaxial Digital Input
Yes - Coaxial Digital Output
Yes - Optical Digital Input
Yes - Optical Digital Output
Yes
- Type
none
- Type
universal remote control - Remote Control Technology
infrared
- Supported Devices
CD player, DVD player, TV, VCR, cable box, cassette deck, satellite TV system - Features
code search function, macro function, multi-brand compatibility
- Type
Amplifier - Frequency Response
100 dB, 70 dB
- Type
none
- Form Factor
internal - Power Outlets
2 AC outlets
- Type
7.1 channel audio line-in, AM antenna, FM antenna, S-Video input, S-Video output, SPDIF input, SPDIF output, audio line-in, audio line-out, audio line-out (multi zone), component video input, component video output, composite video/audio input, composite video/audio output, headphones, monitor output, remote control, speakers output - Qty
2, 3, 4, 7 - Connector Type
4 pin mini-DIN, RCA, RCA x 2, RCA x 3, RCA x 8, TOSLINK, banana/spade x 2, mini-phone 3.5 mm, phone stereo 6.3 mm - Connector Location
front, rear
- Type
none
- Depth
15 in - Width
17.3 in - Height
6.6 in - Weight
30.64 lbs
- Shipping Width
21.5 in - Height (Shipping)
9.9 in - Shipping Depth
17.9 in - Shipping Height
9.9 in - Shipping Weight
35.27 lbs
(B)
Characteristics
- home theater audio system with receiver, 5 speakers and subwoofer
- built-in Dolby® Digital, DTS®, & Dolby Pro Logic® II processing for surround sound from DVDs, video games, and stereo sources
- 6-channel amplifier (40 watts x 4 for front and surround speakers, 100 watts for center channel, and 100 watts for subwoofer)
- 1080p-compatible HDMI video switching (2 in, 1 out)
- 3 A/V inputs (including one front-panel A/V input)
- video output for TV (including HDMI, component video, S-video, and composite)
- digital inputs: 2 optical (1 front panel), 1 coaxial
- built-in controls and connection cable for iPod
- USB input allows a connection to an MP3 player or USB memory drive
- multibrand remote control
- receiver: 4-11/16"W x 10-15/16"H x 9-11/16"D
- 2 front speakers:
- dual 2-9/16" drivers
- 3-15/16"W x 4-1/8"H x 4-3/16"D
- center speaker:
- 2-9/16" driver
- 2 surround speakers:
- subwoofer:
- 6-5/16" driver
- bass reflex (ported) enclosure
- 10-1/2"W x 10-11/16"H x 6-3/16"D
