Btw, almost forgot to say that our client collected his SCM40A's earlier on today and a short while ago he sent me a a pic. of his system
tap the lossless logo and it wil tell you the bit rate it will throw out
and in the setting on the iPad you have to tell it you want to pass through 192 if available.
Thanks for this, I’ll have a play with the settings tomorrow, but if I have this right, my amp is limited to 24/96 so anything above this would be pointless?
Theres a half way house option as well
And, surely, that's all that matters. Seems like you made a great choice with those speakers.All I know is that it sounds great
synergy is exactly that, musical genres is irrelevant, the speakers don't know what sort of music you are playing.....I presume you have good synergy with ATC & Hegel amp, is this in most genres of music?
Halfway house?
I have had a look this morning and the settings on my iPad Pro are lossless up to 24/48.
The bumf on the Apple website states that lossless will be 16bit/44.1KHz or cd quality. This is what I am getting 95% of the time. My guess is that the 24/48 setting will appear for new music added to the catalogue but I could be totally wrong.
This morning’s listening of Sonny Rollins Saxophone Colossus via AM on lossless middle setting on the iPad is showing as 44.1KHz on the amp, my presumption is that it is being played at 16/44.1 CD quality.
Then that's all that matters, i was just responding as you asked how to check, but id max everything out then you don't have to worry and you can leave it to its thing. Whether you hear a difference that a tail as old as time.
Its a great little set-up.
I understand the above yet I had a Naim system with Epos speakers and the 'synergy' was very good with most music but Classical music was a bit wanting. Play something like the Pogues or Santana the synergy was there in spades yet play something like Wagner's Ride of the Valkyries the sound of the orchestra was not exactly there which I put it down to the Naim components. Hence the reason for my question as to most genres of music.
If I do pick up music from a genre that I don’t usually listen too then I am unlikely to know if the sound is good, bad or indifferent..
Can I ask why the spikes not used?Btw, almost forgot to say that our client collected his SCM40A's earlier on today and a short while ago he sent me a a pic. of his system
