Need new power cable
FennerMachine
83
I need a new power cable for my Isotek Cleanline power supply as I moved it and need a longer cable to reach it properly as there’s not much slack left, need about 2.5 or 3 meters.
I am thinking of getting the Clearer Audio Copper-Line Alpha One.
Is it worth getting a cable like this if all the cables from the Isotek to all the other kit is using standard power cables?
CnoEvil
556
14
Surprising as it may seem, it may still be worth doing, as I've heard it can make a difference....but I've not tried it for myself.
I think it's worth discussing it with Darren (Clearer Audio), and if he says it's worthwhile, try it, and you can always return it if you don't hear a difference.
If that is the case, it's clear that such products don't do the job adequately. Many miles of electrical cables to your home with "dirty electricity", another couple of metres shouldn't really make any difference. Clearline should still be able to cope with it.
You don't really have to experiment with a new expensive cable. You already have a "high quality cable". Just buy a cheap one & compare yourself.
CnoEvil
556
14
BB, we just aren't going to agree on this...which is fine.
I'm not telling the OP that it will work, only that he should not be put off giving it a try.
Here is Shunyata's explanation to your comment about "miles of cable" (at point No.5):
http://www.shunyata.com/Content/DTCD-faq.html#_5
There is enough uncertainty in this area to make personal experimentation advisable.....I'm just being "devil's advocate" in this debate.
BB, we just aren't going to agree on this...which is fine. I'm not telling the OP that it will work, only that he should not be put off giving it a try. Here is Shunyata's explanation to your comment about "miles of cable" (at point No.5): http://www.shunyata.com/Content/DTCD-faq.html#_5 There is enough uncertainty in this area to make personal experimentation advisable.....I'm just being "devil's advocate" in this debate.
But Shunyata's explanation does not cover OP's case. The OP has an Isotek cleanline power supply at the end of the power cord (although Shunyata has also clearly stated that its data is not valid in normal home use conditions, already discussed elsewhere :) )
CnoEvil
556
14
The logic states that the one feeding the conditioner is the most important, as it feeds everything else.....but as I say, I haven't tried this, so can't confirm. Maybe the OP should also give Isotek a call.
There are some fellow loons discussing it here:
http://forum.audiogon.com/cgi-bin/fr.pl?fcabl&1181162420
FennerMachine
83
The cable I would have got would have cost £51.50, 3 meter with right angle IEC.
An Isotek one at 1.5 meters costs more than the total cost of servicing my Quad 44 including postage both ways! Possibly a false economy, but never tried a high end mains cable. I know the Isotek Cleanline made an instant massive difference so maybe a power cable will also.
I might get one to try as they do have a 60 day money back guarantee (Clearer Audio).
CnoEvil
556
14
I wasn't meaning to suggest that you went for the Isotek cable, but quizz them about the principal.
If you go for the CA one, just double check they will take it back, if your one is bespoke.....though I've always found Darren very reasonable.
Let me know how you get on
Cno
FennerMachine
83
No worries CnoEvil, I value all the input given from everyone!
I was just highlighting the extreme price differences between different mains cables as shooter mentioned Isotek do there own cables but are pricey (I was agreeing with him). I think the Clearer Audio Copper-line Alpha is the second cheapest What Hi-Fi review after a £4.00 cable.
Checked the Isotek Cleanline manual and it implies good quality mains cables would be beneficial.
I don't think that £150.00+ on a single mains cable makes good economic sense when I could change 4 cables for that with the Clearer Audio cables, but who knows.
I'll report back with my findings!
CnoEvil
556
14
I agree.....I like the Alpha+ (for the rest of the kit)! ;)
