You probably already figured out that this is a philosophical quetion. If you are not much into Hi-philosophy you may want to stop here.
Over and over again we see people (including myself) asking recomendations about products, what is the best AV receiver, or what is the best speaker, blue-ray, etc.. In 99 % of the case the replies are never the same and, when they are the same or similar it is in most cases when people make a recommendation based on the magazine reviews, not even his own reviews.
I believe it is very very very difficult to give an opinion about a Hi-Fi component on its own. The result is totaly different as soon as you change any of the rest the other components; Blue-ray, speakers, subwoofer, cd player, room, speaker possition, etc, etc, etc.
In addition once you add a new component you have to configure it to match the rest of the system; speaker levels, equalization, DTS modes for each input, etc. My experience is that every time I have changed any of the components, it has taken me from 2 weeks to 1 month to completely tweak the settings until it gives its best in my room and with the rest of the components.
For those 2 reasos is why I also find it very difficult to even relly on the limited testing you can do at the hi-fi shops (if any). It is very difficult to test things in same conditions as you would be back at home.
What is your opinion? You believe that opnions about separete components have any value appart from a pure technical/features description?
