jk1988:
Thankyou very much will there be anytime that I can use 'Dynamic'
And how do you get Screen Burn and How do you prevent that if possible.
Personally I would never use the dynamic settings as not only does it look awfull but makes your eyes ache after a few moments. I use either the standard or movie settings on my Samsung which after correct calibration can look quite stunning. Just make sure you don't have yourbrightness and contrast set too high, I think your Tv also has a option to adjust the cell light, if so make sure this is not set too high.
Your samsung will also have built-in screen burn protection so make sure you are using it, there is the very good pixel shift which I have set to shift 2 pixels every 4mins.
If you have any issues with temporay retention, a few mins of normal TV viewing should clear it, other wose there are a few paterns under the screen burn options on your TV which will clear any minor retention quite quickly.
