How to get the best sound out of my PAnasonic BD50 with my Denon 1907 amp?
I have just bought a Panasonic BD50 Blu Ray player.  The problem being, the player has Dolby True HD Decoding yet my amp does not have HDMI inputs.  Now, I cannot afford to upgrade my amp to accommodate for this, but I want to make sure that I get the best sound possible.  I currently have the Blu Ray connected via Coax, is there a better way that I can get the optimal performance or have I got it set up the best way possible?  PLEASE HELP!
Hi there,
By using coax, you're not getting proper HD audio. However, both your Blu-ray player and receiver are multi-channel analogue compatible, so just pick yourself up six analogue interconnects (three pairs in all likely-hood), and your BD50 will be able to decode the HD audio and output it to your receiver. Remember to calibrate your speakers (distances, levels, etc) from within the Panasonic's menus, though.
