HIFI TERMS
Nadeac
69
Anybody enlighten me on various hifi terms
EG Brightness ,Soundstage Etc Etc
Thanks Mark
Hi Mark.
Some of the most common ones:
Brightness - how "sharp" something sounds. i.e. if there is too much treble (cymbals/tambourines are so sharp they hurt the ears) then it might be "bright", whilst not enough is "dull"
Soundstage - imagine you are at a Beatles gig, with the Ringo in front of you, John on the right, and Paul/George on the left. If you close your eyes, you would still be able to tell where they were, right? The same applies in HiFi. A good soundstage will let you pinpoint where each performer is performing from. Obviously, this also depends on the recording.
I'm sure there are some more, and that someone else will chip in with them...
Ok thanks for replies ,surly though when people say an amps to bright or the speakers are to bright isnt this what the tone controls are for ?
Another one iv just remembered is CLIPPING ,is this like distortion ? theres probably a load others ,just cant remember at the moment
Like u say though a good thred to keep sticky for newcomers
Maybe whathifi could even write there own
Mark
Well there's one in the magazine every once in a while........
Yes that's what tone controls are for, but the higher up the hifi chain you go, the less likely an amp is to have them, as they detract from the supposed goal of complete faithfulness to the original source - hence you have to match components carefully to get a presentation you like - if all of your components are 'bright' then you can end up with a sound that's too 'bright', for example.
JohnDuncan:Unless it's "bright" + "bright" + "bright".
Or just Cyrus for short.
"Chalky describes a texturing of sound that is finer than grainy but coarser than dry."
It's hi-fi, not bloody wine!
Hughes123:"Chalky describes a texturing of sound that is finer than grainy but coarser than dry."
Loving also their distinction between "ambiance" and "ambience", which is ballacks.
gwynne61:
http://www.stereophile.com/reference/50/index1.html
One from across the pond
Ha Ha Ha Ha
Get this:
vowel coloration: A form of midrange or low-treble coloration which impresses upon all program material a tonal "flavor" re~sembling a vowel in speech.
More like bowel coloration..........
How about, sounds bad, sounds ok, sounds good, sounds excellent?
